1988 Camaro Hood Hyrdolics
Car: 1988 Camaro RS
Hi,
My camaro's hood hyrdolics are shot and these cars dont have the standard metal bar to hold it up. Does anyone know where I could find two hyrdolics for it and roughly how much? Thanks for your help
Re: 1988 Camaro Hood Hyrdolics
Bought my car a little over a year ago, had the same problem. Hood would't even think about staying up.
At anyrate, I bought mine from AutoZone. Should be able to get them from any parts store. Think I had them look it up on the computer.
If I remeber correctly they were $30.
Put them on then realized that my car does have a hood prop.
Ohwell nice to have them.
Car: 1984 Camaro Z28
Engine: 305 H.O
I got mine from the junkyard for free but for a while i was having to use a big 1in copper pipe hahha all i had.... but im sure they are on ebay if i remember.. i believe they were around $30-35 a pair....
Car: 1982 Camaro Z-28
Transmission: manual
A while aho when I first bought my 82 z-28 the hood hydrolics got stuck in the up position and i couldnt get the hood down. I ended up removing the entire hood and went with a pin down one I bought from my my buddy. Is that a common thing with the stock hoods? Or was I just trying to close it wrong?
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
yeah... where is this hood prop?
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
A lot of people don't realize it, but the gas struts for the hood and hatch on our cars are a regularly stocked parts store item and are fairly cheap. They are a normal wear item just like a drive belt, starter or water pump. There is no need to go to a junkyard to buy a used set or to buy them online and pay for shipping.
lol! why didn't you just remove the gas struts and replace them with new ones??? And I've never heard of that happening before. Was your hood steel or composite? All I can think of is that someone put the stronger struts made for the steel hood on your car with a composite hood and you felt the hood flexing before the struts started to compress so you didn't push it any further.
Car: 1990
Axle/Gears: stock
if you just want the hood to stay up the cheapest is pepboys. they make aftermarket one for the hood and for the rear window. dont want the numbers to show that they are not original, use some paint remover and take the writing off and they are just black.
you can also go to kragens or any cheap parts house.
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
