Turn signal Arm and switch
Old Nov 28, 2008 | 12:35 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Does any know what the part numbers are for a turn signal switch and lever is on an 88 Camaro IROC, cruise, tilt wheel, pulse wipers.
Old Nov 29, 2008 | 08:12 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Turn signal Arm and switch
Not sure on the part number, but you can get a new one from Autozone:
http://www.autozone.com/R,1010041/st...ductDetail.htm
Old Nov 29, 2008 | 08:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Proceed at your own discretion:
http://www.moderndaymuscle.com/interior1?b=1
JamesC
Old Nov 29, 2008 | 08:36 PM
burnout88's Avatar
Car: 88 IROC
Thanks guys, I was able to find a new GM one at my local dealer. I try to stay away from the autozone china parts when possible, but man that is alot cheaper for the aftermarket one 39.99. The GM list price for a new one is $178.08, I got it for 124.00 with the wholesale discount at my local dealer.
In case anyone else needs the part numbers
25111262-Turn Signal Lever Signal lever - W/cruise control
W/pulse wiper - W/tilt column 1985 - 1991
25111263-Turn Signal Lever Signal lever - W/cruise control
Without pulse wiper - W/tilt column 1985 - 1991
I would have ordered from Modern day muscle but I needed one asap.
Old Nov 30, 2008 | 05:58 PM
Kandied91z's Avatar
i got mine on ebay $14 shipped 3 day looks identical and works like a charm.
also rockauto.com is a great source for those things. have the time all those electronic parts are made overseas or in mexico anyhow. i can see some oem things but paying $100+ more ouch that hurts.
Old Dec 6, 2008 | 02:12 PM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
i got mine off ebay it was like $11 no cruise no delay but it was an oem piece
Old Jan 18, 2009 | 04:37 PM
thekevin's Avatar
Car: 1985 Z28
Axle/Gears: 3.23 open
Just out of curiosity, how hard are they to change.
Old Jan 19, 2009 | 07:39 AM
JamesC's Avatar
No experience, but I've read that the stalk simply pulls out (make sure you have a line on the wiring so that you can pull it back down through the column). A search would no doubt provide the info you're seeking.
JamesC
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
