CENTER CONSOLE PROBLEMS
Old Dec 11, 2008 | 10:27 AM
Daapunk's Avatar
Car: 88" Trans am
Engine: 350 bored. 383 Stroker Kit
Transmission: Power Glide
Axle/Gears: 4:10
I have a very pristine '88 Trans am.Everything on the car is in near flawless condition. However, the center console has the same problem as most Firebirds of the same years. The soft rubber/plastic (?) that covers the center console is peeling away from the supporting structure beneath. My brother and I tried hot glue on his center console (an '89 Firebird) and held it in place for a few hours with small clamps, but that didn't hold up more than a week or two.
Does anyone know of a way to repair this problem cleanly and permanently?
What type of GLUE or adhesive would stick and hold?
Old Dec 11, 2008 | 12:29 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: CENTER CONSOLE PROBLEMS
You might want to try some two-part epoxy.
Old Dec 11, 2008 | 01:44 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
When mine did that all I used was Loctite Superglue. It has been 2 years now and it still hasnt come apart.
Old Dec 11, 2008 | 01:48 PM
Daapunk's Avatar
Car: 88" Trans am
Axle/Gears: 4:10
yea think ima try some locktite superglue if urs worked. i thought of epoxy also just trying to get some users ideas. thx
Old Dec 11, 2008 | 02:02 PM
gunner53227's Avatar
Car: 86 TRANS AM
Transmission: 700 R4
Axle/Gears: 10 bolt/3.73
I'm having the same problem also. I'm in the process of making a small plate, welding studs on one end, then placing them on the center counsole so it will pull the sides together. I might not be explaning it very well, but after finals I will finish and I will have pics.
Old Dec 11, 2008 | 02:30 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Alright guys,
Here's how I fixed my bird's center console when it was peeling away just like what you guys are dealing with.. In my case, I had both sides of my console peeling away...
Take out the shift plate.
Take the console out of the car.
Where the material is peeling back and wherever else you want to reglue, remove some of the old foam under the material that has seperated, so you have a nice place for glue to go.
Get some really big wood clamps, (the ones that can stretch to like 4 ft)
Get some Gorilla Glue (Awesome stuff)
Get 2 pieces of wood (2x4 or whatever you can find) and cut them to the length of the console.
Put a bead of glue under the material where it has separated (Gorilla Glue expands a good bit so DO NOT go overboard with the amount of glue, unless you want a bad mess later)
Clamp the pieces of wood to the sides of the console so it holds the material to the console and so the glue can do its job. (Don't clamp them too hard or you will get imprints on your console.
Wait a couple hours and remove the clamps.
Install console back into car.
You're done!
Old Dec 16, 2008 | 07:50 AM
uemf's Avatar
Car: '86 Firebird
Engine: '85 TPI on crate 350
Transmission: T-5 man
I agree with the Gorilla Glue. I used it on my center console and it holds well.
Old Dec 16, 2008 | 12:29 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Using big clamps and pieces of nice straight wood to distribute the clamping force is a very good tip.
Its the only way to get the sides to lay nice and flat and straight. Otherwise, you'll see the wavy sides like you do in alot of cars where the people just try to hold them by hand til the glue sets.
Another vote for Gorilla glue...you cant go wrong with any of those products in my opinion...
J.
Old Dec 16, 2008 | 03:31 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Check out E-bay, sometime they have new concole lids forsale.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
LittleFranks
Sep 17, 2015 12:22 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
Firebird sweden
Aug 16, 2015 05:02 PM
