An alternative to the poor fitting 4thgen door panels
Old Jan 11, 2009 | 01:32 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I have 4thgen panels in my car right now. But let's face it they have many flaws and need a ton of work and will never look 100% on the money. So opted to blend the newer T/A panels with 4thgen components.
It's fairly easy to do I did a bit of glassing to get everything right and it looks pretty much factory I also used some of the 4thgen back board to get the outline for the handle area just right. It's also a good choice for those with stock dashes and want a nicer panel. I am going to make some speaker boxes at work that will go where the map pocket was. I also bought some nice vinyl to do these in but I do not have the skill at this point to work with vinyl and get it to look perfect so I chose felt for now.
Here is a few pics:
Started with this idea:
There is no good way to make the lower part work it just doesn't flow all that well so I ditched that part.
Basicly you glass in this area so you can make it smooth for the material , I bonded the 4thgen backboard handle area and then glassed over it , then sand sand and sand some more.
Glassing/test
Old Jan 11, 2009 | 01:48 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: An alternative to the poor fitting 4thgen door panels
NICE!!!
Any "in progress" pics by chance?
Old Jan 11, 2009 | 02:00 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Added
and another closeup
Old Jan 11, 2009 | 09:23 PM
DanTeix's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
Looks cool I would have gone with a Vinyl or something but definetly a good alternative. Might steal ur Idea
Dan
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
