How the hell.....
Old Feb 5, 2009 | 08:07 PM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
How the hell.....
....do I get this off?
I was trying to get my back seats off but couldn't figure out how. I have split seats.
Old Feb 5, 2009 | 08:16 PM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
Transmission: 4 sp. Auto-4L60
Re: How the hell.....
I can't tell what I'm looking at. Can you get a little further out?
Old Feb 5, 2009 | 08:19 PM
Stippy17's Avatar
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
If that is a pic of the back of your seats, then your asking about the rod that goes through the hump I am guessing.
Ok, to remove one back seat you need to unbolt it from the side against the side of the car. It should be a 13 or 15 mm I believe. Then you need to pull the seat towards the side of the car, and the rod should come out of the back seat. You will need to do the same thing for the other back seat.
Old Feb 5, 2009 | 08:23 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Yep, Stippy17's got it. Here's a link to a thread that has a couple replys that say basically the same thing.
Old Feb 5, 2009 | 08:45 PM
Guro 305's Avatar
Axle/Gears: Stock
So I take it I have to remove the seat bottom first then?
Old Feb 5, 2009 | 08:49 PM
Stippy17's Avatar
I have done it with the bottoms still in and having them out, and it makes it alot easier/faster with them out. They are held in by just one bolt in the front thats a 13 mm I believe, and you may or may not have velcro in the back. Pretty simple to do, and then you have alot more access to the nuts on the sides.
Old Feb 5, 2009 | 10:11 PM
Guro 305's Avatar
Axle/Gears: Stock
Well I had already replaced the bottoms before. Since it's been cold I figured I'd reupholster the seat backs.
Old Feb 5, 2009 | 10:41 PM
Stippy17's Avatar
Then you should be fine. Let us know if you need any more help getting the backs out.
Old Feb 9, 2009 | 01:22 AM
Guro 305's Avatar
Axle/Gears: Stock
You were right Stippy, I removed the seat bottoms and they were a sinch to pull out. Just slid out after removing the nut.
Still can't find a fabric to match the color though. I just gotta be patient. I don't use the back seats anyway......anymore.
jo3y1nf4nt3
Feb 11, 2008 12:56 PM
Leo_padakin
Apr 26, 2006 06:23 PM
HamSpiced
May 18, 2003 05:23 PM
badgta
Dec 26, 2002 03:29 AM
383 Smoka
Carburetors
Jun 23, 2002 07:19 PM
