can a gauge cluster from an 88 iroc fit into a 91 rs and work correctly?
Old 02-17-2009, 03:35 PM
stppws4e's Avatar
Car: 88 IROC/91 RS
Engine: 5.7 350
if you know,please throw me some advice
Old 02-17-2009, 03:54 PM
JTB91RS's Avatar
Car: '91 Camaro RS
Engine: Carbed 350
Re: can a gauge cluster from an 88 iroc fit into a 91 rs and work correctly?
As far as I know, the '88 cluster will physically fit in the dash opening, but you will likely need to use the dash/cluster trim from the '88 IROC too. Also, the '91 uses an electronic speedometer, while I believe that the '88 is mechanically driven, so you would have to remove the VSS currently installed on your transmission and replace it with a mechanical gear/cable unit.
The short answer is yes, it will fit, but it is not 'plug and play', and it will require some additional parts besides the cluster to correctly install it and make it work.
Old 02-17-2009, 06:19 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I believe the opening is totaly different, as the 90-92 dashes were more rounded everywhere, and like said above you would have to change your electric speedo to cable.
Old 02-17-2009, 06:47 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
89 is correct.
JamesC
Old 02-17-2009, 06:56 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Originally Posted by JamesC
89 is correct.
JamesC
The older circle style gauge clusters will not work in the newer clusters. The speedo is mechanical on the older ones and the speedo is electronic on the newer ones. Not to mention the shape of the cluster is totally different IIRC. Im assuming you want the speedo cause it goes to 145mph??
Old 02-17-2009, 07:06 PM
JamesC's Avatar
If so, purchase a 145 designed for the 90-92 cluster--half moon with yellow markings, electric as mentioned.
JamesC
Frozer!!!
01-19-2024 04:55 PM
Ghettobird52
12-29-2023 08:23 AM
fonzie85
08-13-2015 11:50 AM
Armored91Camaro
08-12-2015 09:41 AM
mustangman65_79
08-11-2015 03:17 PM
Quick Reply: can a gauge cluster from an 88 iroc fit into a 91 rs and work correctly?
