Fast Repair of Loose Steering Column
Old Mar 6, 2009 | 04:40 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Well my steering column was getting more and more loose by the week and I had suggestions here on how to tighten it up, but I really didn't want to deal with getting the special tools and all that. So I took it to Empire Steering Column in Rialto CA, was a half hour drive and took Angelo about half hour to get it all tight again, they specialize in steering columns and they were recommended by another member on here a while back. Cost $80. Later.
Old Mar 6, 2009 | 05:12 PM
Stephen's Avatar
Car: 87 GTA
Re: Fast Repair of Loose Steering Column
Yeah...I had mine done for $100.
They said there was only ONE of the 4 bolts still in place, and it was only in by a few threads!
Old Apr 6, 2009 | 07:38 PM
GunmetalForm90's Avatar
Yeah i did mine myself.
Took a grand total of EIGHT hours. Took it apart and put it back together THREE times. The parts were a pain, and i had to helicoil all four bolts.
I will never do that myself again.
Old Apr 6, 2009 | 08:03 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Ended up replacing the column housing (mine was an 87 column) with one off of a 90 GTA, a much beefier unit. Took all of my innards and put them in the gta column, mine was so bad the column itself had broken apart. I felt it let loose when I had to jam the brakes at speed. Friggin scary man. The repair took 8-9 hrs. Not including getting the junkyard column. Had the help of a friend whose done a couple! Don't think I could of done it alone? What a pain...
Old Apr 9, 2009 | 01:19 PM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
Engine: 5.8L TPI 355 L98
Hey stephen where did you have yours done at?? I live near houston and i need to get mine done. I work at a chev dealer but they wanna charge me an arm and a leg.
Old Apr 9, 2009 | 01:25 PM
Stephen's Avatar
Car: 87 GTA
Small town (Bertram, TX) local shop, which is now closed. Maybe they weren't charging enough for repairs, to pay the bills?
You went to a stealership.....That was your first mistake!
Ever since then, I no longer use my steering wheel as "leverage" to get in or out of my car. It wasn't loose when I bought the GTA 2 years earlier.
83 Crossfire TA
Jan 3, 2016 01:26 PM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
mrdevontay
Sep 2, 2015 08:04 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
