replace steering wheel
Old Mar 16, 2009 | 04:07 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
I want to replace my steering wheel on my '90 RS, I believe it was the first year to have an airbag, but what do I need to do to remove the steering wheel? Do I need a special tool to remove the steering wheel once the airbag has been removed? Thanks in advance
Old Mar 16, 2009 | 04:25 PM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
Re: replace steering wheel
once you get the airbag out the wheel comes off like any other wheel. just get a steering wheel puller and you shouldn't have a problem. you will however have an airbag light on if you are putting an aftermarket wheel on it.
Old Mar 16, 2009 | 04:48 PM
Stephen's Avatar
Car: 87 GTA
Not only the light problem, but check to see if your car will pass at inspection time without an airbag, if it is going to be a street car.
Old Mar 16, 2009 | 04:59 PM
Sean_of_PeriaH's Avatar
What about putting a newer steering wheel on?..like a Pontiac G8 steering wheel. Is it possible? Will the airbag work?
Old Mar 16, 2009 | 05:16 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
To my knowledge, thats considered a dual state wheel, not to mention if the splines will line up/add up. You should be able to use a 4th gen firebird or camaro steering wheel though, as many people have wired them in and had no problem. Doing a search would provide more detailed and crutial details about that.
Old Mar 17, 2009 | 12:44 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
I just passed my inspection in january and i could pay them a bit extra to "forget" about the steering wheel, i'm sure, so that's not a problem for me, but is there any way to get that airbag light to shut off?
Old Mar 17, 2009 | 04:07 PM
89N10GTA's Avatar
Car: 1989 GTA
you could pull the bulb. that would be the only way to turn it off.
Old Mar 17, 2009 | 06:22 PM
teal's Avatar
I heard from somewhere that if you place 2 ohm resistors on the wires on both ends of the pigtails that it could turn off the light. Not verified just told to me by an auto body guy.
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
