steering column upper bearing install
Old Mar 25, 2009 | 08:05 AM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
i searched but couldnt find much on this but when installing the new upper bearing does it get pressed in? ive been told yes and then ive been told no, to just set it in and the spring would press it where it needed to be... a lil advise here would be awesome yall......
86 IROC
Old Mar 25, 2009 | 02:27 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: steering column upper bearing install
Welcome to TGO. Not real sure which bearing you're talking about but if its the bearing under the lock plate the cup and spring will hold it in place. A little more info is in this post:
https://www.thirdgen.org/forums/faq-...eels-like.html
Old Mar 26, 2009 | 06:05 PM
_87GTA_'s Avatar
For what it's worth, I busted my bearing out in the process of changing a key cylinder. Instead of fixing them, I just bought a used entire column for $75 shipped, and installed it. It is VERY easy to install the entire column, dare I say......easier than changing the damn key cylinder alone.
Old Mar 28, 2009 | 09:20 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
There's a spring right behind the locking plate that holds the bearing in place. Once you remove the locking plate, the spring will be slack, and the bearing can be removed/replaced/etc. Here's a quick drawing I did a while back showing how it goes together:
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
red90IROCls1
Aug 25, 2015 06:56 AM
Bull86
Aug 10, 2015 05:43 PM
