Interior Photos-What Is This Option?
Old Mar 31, 2009 | 07:18 PM
Flynt's Avatar
Car: 1988 Camaro IROC
Transmission: Auto overdrive
Axle/Gears: 3:23
This is my friend's 1989 IROC and we both want to know why some Camaros have this lid in the trunk and others don't. Is it an option? If so,what is the option code?
Old Mar 31, 2009 | 07:26 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: Interior Photos-What Is This Option?
It was an option.Locking rear floor storage cover.Not sure of the rpo code.
Old Mar 31, 2009 | 07:30 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
they are hard to find and even harder to install. there was a special welded on brace but you cant do tht now - there is a gas tank in the way. the dealers dont have any left, i tried to find one that way. the braces are done at the factory - so no luck there either.
i had to prefab a brace up and then had it bolted in, but that was trickey because you cant just run the holes, or you put a few in the gas tank.
but they are nice. and they qualify as a trunk so you can carry guns in there, when you go to the range.
Old Mar 31, 2009 | 07:51 PM
armac's Avatar
Car: 83 ta
It is part of option code B48 luggage compartment trim
Old Mar 31, 2009 | 08:13 PM
Flynt's Avatar
Axle/Gears: 3:23
Armac,
Thanks! That is what I was looking for. Do you know what years Chevy offered B84?
Old Mar 31, 2009 | 08:29 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
ooooooh i want one
Old Mar 31, 2009 | 08:48 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Cover, locking rear storage (RPO D27) 84-89. Std. on Berli. Not particularly rare.
JamesC
Old Mar 31, 2009 | 09:29 PM
Flynt's Avatar
Axle/Gears: 3:23
Guys,
Now I am confused. Is it option code B84 or D27?
Old Mar 31, 2009 | 09:38 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Not sure of the code either but my son's '92 Z has the Bose system from GM and the cover has the 2 speakers and amps on it...
Old Mar 31, 2009 | 10:52 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
RPO decoder says its D27.
Old Mar 31, 2009 | 11:11 PM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Pics?
Old Apr 1, 2009 | 12:18 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The complete option code is B48 - Luggage compartment trim. It included carpet inserts on the plastic rear interior panels and the locking cover panel over the trunk well. The physical RPO for the locking panel is D27. I want to say B48 was availble from '82-89 or 90. As "daferris" noted above, the locking panel was also used on Camaros with the Bose radio option.
My '82 T/A has the option. Its nice as it makes getting the T-Tops into the storage bag a lot easier.
Old Apr 1, 2009 | 05:29 AM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
If this is hard to find... is it rare in both Camaros and Firebirds, or just Camaros? My '86 TA has it.
Old Apr 1, 2009 | 09:38 AM
matj1990's Avatar
Car: 83 firebird/camaro conversion
Engine: carbed 350 very mild build
Transmission: th350
Axle/Gears: 3.42 posi
myn has it but idk what part of the car it came with
Old Apr 1, 2009 | 10:59 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I have one of those with black carpet if you're looking to buy one. I don't have the weld-in brackets or matching rear trim piece that has a ledge for it to sit on though.
Old Apr 2, 2009 | 06:48 PM
GFR88IROCZ's Avatar
Car: 86 Sport Coupe
Engine: LG4
Transmission: BW 5 speed
My 86 Sport coupe lists RPO B84 and has no traces of this cover or any place it may have mounted.
Old Apr 2, 2009 | 08:58 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
B48 is luggage compartment trim. That's it. It is the carpeting trim on the wheel wells and rear panels. D27 is the rear locking cover and has nothing to do with B48.
Old Apr 2, 2009 | 09:08 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
do you have a template of the braket? i have this option but the owner before me cut the bolts off so i dont know what to do!
Old Apr 3, 2009 | 01:45 AM
Dens71TA's Avatar
B48 is luggage compartment trim and included D27 rear locking cover. They were not separate options. See attached pic of a dealer order form. Under option B48 it notes "Inc. Rear Compartment Storage Cover". There is no separate D27 option on the order form.
The '82 brochure has a picture showing B48/D27 with the caption "Available cargo trim includes carpeted sides and lockable storage compartment door"
To get D27 you had to order B48.
Old Apr 3, 2009 | 01:57 AM
Dens71TA's Avatar
B84 is body side molding.
Old Apr 4, 2009 | 12:08 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
I used to have one of those on my ride, the previous owner created a sub-box out of it and used it as a flip up sub box. It was surprisingly nice. I wish I had pics of it.
Old Apr 5, 2009 | 01:15 AM
Darth Satanis's Avatar
Car: 86 Firebird
Engine: Buick 3.8 V6 Turbo
Transmission: 200r4
Axle/Gears: 3.42's
Those covers are also different for the 82-85 and 86-92 cars, because of the power pull down motors.
Old Apr 5, 2009 | 05:35 AM
ThePain's Avatar
Car: 1992 RS
Old Apr 5, 2009 | 11:56 AM
Dens71TA's Avatar
Starting in '86 GM started to put an electric power pull-down trunk latch so the hatch didn't have to be slammed closed. You just lightly push down on the hatch until you hear a click sound and then the motor activates and pulls the hatch fully closed This is the same system that Cadillac has used for decades. The pull-down latch is considerably larger than the simple standard latch used on '82-85 cars so the rear plastic trim panel has a larger bump in the center. The D27 trunk well cover had to be redesigned to fit the pull-down latch style rear trim panel.
So there are rear trim panels and D27 covers for '82-85 with the standard latch and '86-92 with the electric pull-down motor latch.
Old Apr 9, 2009 | 09:52 PM
Ca[maro]88's Avatar
could you maybe take more pictures of it? like the ledge that it sits on?? i wanna make one really bad.. cheapest one i could find was 50 bucks on ebay
Old Apr 9, 2009 | 10:30 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
I think the lockable storage they are talking about is the standard side storage on the left. B48 certainly didn't include D27 in 1986 as my car has the carpeted trim (B48) but not the locking cover in the pics above.
Old Jul 12, 2015 | 11:07 AM
captdantman's Avatar
Looking to sell my "rear compartment lockable storage bin lid" for 3rd gen. I bought this for my 92 so it should be for that year. $150.00
Old Jul 12, 2015 | 11:43 AM
JamesC's Avatar
For better luck, try our site's classifieds.
JamesC
Old Jul 12, 2015 | 11:46 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
I'd make a new post under classifieds instead of bumping a thread from 2009
Old Jul 14, 2015 | 10:02 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
That's not a 92 part,.... the 92 BOSE used bigger rear speakers. That one is from an 87 or 88 most likely.
Old Oct 24, 2015 | 10:48 PM
Old Iron Worker's Avatar
Car: 1986Trans, 1979 lincoln continental
Engine: Both stock 305HO, & 400 4 barrel
Transmission: 5 speed stick, & stock
Axle/Gears: stock
Do you still have the rear compartment cover and if so where are you located to find out how hard it would be to get it from you, thanks Tim.
Old Oct 25, 2015 | 10:00 AM
Yenipenny's Avatar
Car: 92 RS Heritage
I installed one of those in my 92 RS when it was new and of course bought it through our parts department. As stated before, it was standard with cars with Bose sound system. It appears to take 6 X 9 speakers based on the outline on the back of the lid. Additionally, I can attest to punching hole(s) in the gas tank if you aren't careful. I wasn't careful. My car had/has cutouts in the carpet to guide where to put the bolts.
I see those pretty often on Ebay.
Lanz06
Sep 14, 2015 07:16 PM
angel2794
Sep 8, 2015 06:22 PM
machinist21
Sep 5, 2015 03:03 PM
IROCZ1989
Sep 4, 2015 11:54 AM
