Cleaning the plastic interior panels
Old Apr 4, 2009 | 10:43 AM
tomcat128's Avatar
Car: 1988 Pontiac Trans Am
Engine: L98, built to 383
Axle/Gears: 3.78
I was wanting to know if anyone has found a good way to get the ABS plastic interior parts clean. I have tried several different cleaners but none seem to get the dirt that has worked its way deep into the plastic over 20+ years. If anyone has found something that works I would really be grateful. Thanks
Old Apr 4, 2009 | 10:56 AM
toomany's Avatar
Re: Cleaning the plastic interior panels
If it's really dirty when I get it. I'll take it out and wash it with some hot soapy water and a wash cloth. To keep it clean I use a product by Turtlewax....can't rember the name. But it comes in a green spray bottle.
Old Apr 4, 2009 | 01:02 PM
Hotrod7206's Avatar
Car: 86 IROC
Engine: LB9
you could always try Tri-sodium Phosphate i am going to try it when it gets warmer on the larger pieces that i pulled from junk yards last year. i have had good success on the small pieces that i have.
Old Apr 4, 2009 | 01:12 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Second the Tri-sodium Phosphate, it's used to clean the plastics before they get dyed...
Raf
Old Apr 4, 2009 | 08:25 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I used Dupont 3812S enamel reducer to clean the plastics on my 88 IROC'S Beechwood tan interior plastics. It was the only thing that got the 20 year old grime out. They look as good as new now. You can buy it at Carquest or a bodyshop supply store. My brother owns a body shop and told me about it. They use it for removing glue and grime before painting surfaces. Trust me you won't be disappointed.
Heres a link to a photo of it.
http://www.customclassictrucks.com/t.../photo_04.html
Old Apr 18, 2009 | 04:00 AM
mr60ft's Avatar
Car: 87 black hardtop gta
Transmission: 700r
Axle/Gears: 9 bolt 3.27
i used some goof off to clean my camel door panels, rear plastics, etc. i couldnt believe the difference it made. it even got all the black "shoe" rubs off the bottom of the door panels. I tried every cleaner my wife had in the house before i found goof off. LOL.
Old Apr 18, 2009 | 08:00 AM
tattoogoddezz's Avatar
Car: 92 Firebird
Transmission: auto, unfortunately
Two crazy remedies here that work like a charm for me on some old 50's and 60's parts I dd back in the day....
baking soda and vingear-eats grime away real fast, sometimes they have to soak for a while then scrub but it usually loosens things up real good.
Cocoa Cola- works awesome on anything metal. I kid you not. Soak anything metal in a bottle of store brand coke and voila clean over night.
Goof Off and Goo Gone are my next choices if those don't work.
Old Apr 18, 2009 | 10:37 AM
bruce lamoureux's Avatar
Car: 1991 firebird formula
Transmission: auto.
Axle/Gears: ?
i just cleaned the interior of my 1991 formula with soom armrall cleaner ,you can get the spray or wipes from any auto parts store .i like the spray better it gets in all the little cracks and groves ,then to wipe lhe cracks and groves out i use qutips.it worked good for me,happy cleaning!
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
AkDrifted
Aug 17, 2015 07:45 PM
Street Lethal
Aug 14, 2015 08:25 PM
