wiered cluster ??
Old Apr 11, 2009 | 10:25 PM
craig62989's Avatar
Car: 06 slobalt, 85 IrocZ
Engine: 2.2, 350
wiered cluster ??
any1 seen one of these b4 and know what its worth ?
Attached Thumbnails wiered cluster ??-img00048.jpg   wiered cluster ??-img00049.jpg   wiered cluster ??-img00050.jpg
Old Apr 12, 2009 | 12:03 AM
Mailbox Hunter's Avatar
Car: 89 Camaro RS
Engine: 350 TBI
Axle/Gears: 10 bolt/ 3.23 Gear.
Re: wiered cluster ??
ha ha that's any early 82 to like 85?, maybe, style gauge setup
it only goes up to 85mph thought.
you can find them cheap as far as i know,
most people want take those out and put the 145mph gauge in.
-Rob
Old Apr 12, 2009 | 07:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. 82-84 Camaro. Not a desirable piece unless you're looking for an OE replacement. As Mailbox suggests, most members toss it for something a bit more modern.
JamesC
Old Apr 12, 2009 | 07:43 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i got ones similar to that in my 87 base camaro. replacing them soon with iroc gauges to get more gauges instead of idiot lights
Old Apr 12, 2009 | 10:03 AM
Car: 89 Camaro RS
Engine: 350 TBI
Personally I think I would add this cluster to my car for a little while just to mess around with it. I think its kind of interesting how its double sided.
Old Apr 12, 2009 | 12:11 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
'83 base cluster,'82 and '84 are almost the same but
each year has slightly different markings and numbers.
Old Apr 12, 2009 | 12:29 PM
JamesC's Avatar
Originally Posted by 8t2 z-chev
'83 base cluster,'82 and '84 are almost the same but each year has slightly different markings and numbers.
Here's what I found once upon a time:
I've been searching for a 5500 red line tach to mate to my new motor. What I found at the bone yard was surprising--perhaps because I'd never really looked before. In the first car I checked, an 82-84 Camaro, the red line was 5500. The yellow line at 5000, however, wasn't solid but rather a series of hash marks, IIRC. The second car, another 82-84 Camaro, was also equipped with a 5500 red line. This one had a solid yellow line as do the newer tachs (85-89?), but the font for the numbers was completely different from all others I found.
JamesC
Old Apr 12, 2009 | 04:15 PM
craig62989's Avatar
Engine: 2.2, 350
this is the only other gauges i can find for a 3rd gen i havent been able to find another pic of one like mine
Old Apr 12, 2009 | 04:24 PM
JamesC's Avatar
Looks like the first cluster I describe.
JamesC
Old Apr 13, 2009 | 03:29 PM
crossy's son's Avatar
Car: 91 GMC 1500 pickup, reg. cab shorty
Engine: 350 5.7 TBI
Transmission: 5 speed manual, HLM60
Axle/Gears: 10 bolt, 3.42 G80 posi. all factory
I have that cluster as well from an 85.
Is a 89 IROC 350 TPI 145mph cluster plug and play on a car with an 85mph cluster?
Old Apr 13, 2009 | 04:46 PM
JamesC's Avatar
Yes. But to avoid any possible electrical problems, swapping only the speedo head is the best bet.
JamesC
Old Apr 13, 2009 | 04:51 PM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
looks like a european cluster to me....
louiethebats's Avatar
Car: 1991 Chevy Camaro RS
Engine: 305 BORED to 310
those are bad-a$
if it were simple to install into a 91 i would trade you for mine.
Elephantismo
Feb 13, 2019 12:51 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
James Sutton
Sep 23, 2015 02:18 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
