replace seatbelts
Old Apr 21, 2009 | 02:05 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
replace seatbelts
Hi,
do I need to remove the headliner competely in my 85 ta t-top, to replace the front seatbelts?
Old Apr 21, 2009 | 05:14 PM
mmm88TA's Avatar
Engine: 5.0 TPI
Transmission: TH700R4
Axle/Gears: 3.43 posi
Re: replace seatbelts
it's possible to do it just removing the rear plastic (between the headliner and the hatch), the black plastic inside the doors that support the headliner and the sail panels but be very careful its easy to break the headliner that way. It can be very flimsy and break in half or you could just break the corners apart while working on getting those bolts out from the seat belt retractor. It is possible just be very careful if you go that route.
Old Apr 21, 2009 | 07:27 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Considering the headliner is 24 years old if it still original, I would just take my time and remove it. Chances are it will break when you bend it to remove the belts. If in fact it is original, you might want to remove it anyway and see if it needs any strenthening or possibly a recover.
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
