How to get Manual Window Crank Off w/out ruining it
Old Apr 24, 2009 | 11:59 AM
Dogfrost9's Avatar
Car: 1984 Camaro
Transmission: 350 Turbo
The crank you turn to put your windows down or up on a manual door, I Managed to get one off after a lot of pulling but it basically ruined it. There is a Metal pin or something that holds it on, the rest of it is just plastic. Anyways, i cant figure out how to release the pin. I have my door panels off and ready to put new ones on but need to get that off first.
Old Apr 24, 2009 | 12:05 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: How to get Manual Window Crank Off w/out ruining it
You can use a flat screwdriver but they sell a tool for doing this and they don't cost alot .
Old Apr 24, 2009 | 12:06 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
It helps to have the tool, you can get them at the local auto parts stores.
Old Apr 24, 2009 | 12:17 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Good to have pictures like that to share man thanks for putting them up .
Old Apr 24, 2009 | 12:21 PM
Car: 1971 Camaro
No problem, just a few I found on the web
Old Apr 24, 2009 | 12:25 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Simpler than me going out to the garage and takeing a picture of mine .
Old Apr 24, 2009 | 01:14 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
That tool is a god send and worth its weight in gold
Old Apr 24, 2009 | 01:31 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Yeah it is alot better than trying to get it loose with a flathead screwdriver .
Old Apr 24, 2009 | 04:04 PM
1Aauto's Avatar
Former Sponsor
I think I saw those tools in Autozone.Probably worth having in the tool box.
Old Apr 25, 2009 | 07:57 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Definantly wort having in the tool box .
Old Apr 29, 2009 | 01:44 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
You can do it for free also.... Here is a little trick I learned.
You take a rag, slide it behind the crank, so that the rag hits the points of the clip first. Then using a sawing motion, slide the rag back and forth slightly while pulling against the clip. The clip will catch on the rag, and when you pull against the clip, it will pop off.
My first car was a 67 Bonneville 4 door. So removing manual cranks became a frequent occurance with me. Embarassingly enough, it took me a few times screwing with needle nose pliers, trying to get the clips back in to realize you could install the clip, then pop the crank back on
Some old guy at a body shop showed me the rag trick, and its worked good for me.
J.
Old May 1, 2009 | 09:34 PM
shanewbenson's Avatar
Car: 1992 RS
Engine: 305 TBI
Transmission: IROC 700R4
You can also use a thin rag and slide it behind the handle and kind of slide it back and forth. It will pop the pin right out.
Old May 2, 2009 | 08:42 PM
Car: 86 Trans AM
A rag huh? I think I read that somewhere...
Old Jun 23, 2009 | 01:40 AM
!CamaroDave's Avatar
Car: 87 Camaro IROC, 85 IROC Roadste
Engine: 5.7 V8 350 TPI, 383 - Coming Soon
Transmission: 700R4, Turbo 350
Thanks for the pics and advice! Nice Homework
Old Jun 23, 2009 | 04:44 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Why back in my day, ships were wood & men were steel.
Sumtime us ole farts know a thing-er-three.
Old Apr 5, 2020 | 10:41 AM
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
yep, good tip - saved a few cents buying the tool
K7dan
Oct 26, 2019 04:52 AM
Destro Camaro
Apr 22, 2017 11:35 PM
pmurta
Mid-West Region
Feb 29, 2016 09:46 PM
kitt23
May 29, 2012 07:01 PM
kitt23
Exterior Parts for Sale
May 26, 2012 01:56 PM
