Interior Picture Help Please!!!
Car: 1991 RS Hardtop
Axle/Gears: 3:23
I did a search and wasn't able to turn up a good picture... I'm looking for a picture of the rear drivers side with no interior plastics. Basically on top of the wheel well. I need to fix up a small dent with a TINY bit of rust on the inner wheel well, and I'm wondering if I can get to it from above. I have read that taking out the rear plastic can be a small hassle, so i want to find out if the wheel well is double layered before tearing it apart!
I think that makes sense... Hopefully someone knows what I'm talking about!!
Engine: 5.0 TPI
Transmission: TH700R4
Axle/Gears: 3.43 posi
Re: Interior Picture Help Please!!!
Here's a picture of a hole i found in my drivers side wheel well its the only one i have that isn't an extreme close up.
Axle/Gears: 3:23
Yeah, that is what I am looking for. I guess my question is, is that the tire right under that? or is there another layer of metal before the rubber?
Axle/Gears: 3:23
awesome! thanks again. I pulled the plastic out to, and sure enough... there it was! the well is a little worse than I had thought, but now that it is apart, I can fix it up. might also be a good time to do the headliner since one out of 4 panels is already off!!
Engine: 5.0 TPI
yeah while you're fixing it i'd recommended you also pull the wheel and check the seams in the wheel well and respray some undercoating to prevent future rust
Axle/Gears: 3:23
Yeah, I've actually gone through the other 3 wheels cleaned them up and sprayed rubberized undercoating in there. this is the last one, saved for last because i knew it would be the worse.
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
OK don't want to sound like a know it all or anything but, rubberized undercoating is the worse s**t out there, it causes more damage than good, i have used it and it holds a lot of water, everyone else that i talk to said the same thing, you need something harder and more bondable, something like bed liner, and then a good coat of paint, if you paint rubberized undercoating you will notice it cracks, and that's where water gets in, hope this helps.
Car: 1987 Trans Am
Engine: LQ9/L92
That was exactly the same issue I had with my 89 RS. Went to go install a 9-bolt rear, hand slipped off the wrench, and punched right through to the interior. Wasn't a good day, since I'm not a body work kinda guy. Thats one of the first areas I check when looking for one of these cars. Very happy to find this area solid on my recently purchased 87 TA.
colton_carlson
Mar 8, 2019 12:21 PM
Linson
Aug 21, 2015 02:12 PM
