Autometer mech. speedo problem
Old 05-26-2009, 06:14 PM
customirocz's Avatar
Car: 86 Iroc-z
Engine: worked 350tpi
Transmission: built 700r4
Axle/Gears: auburn pos 4-10
I have an 86 iroc, i made my own dash cluster with autometer phantom gauges im using a mechanical speedometer with cable i didnt know that the original cluster had a vss attached, now i have vss trouble codes and esc.Does any one know if there is a way to correct this problem?Maybe an after market vss that will work i cant seem to find anything that will fix the issue.I also dont have the old cluster anymore so cant salvage the vss if it would have worked or not i dont know. I would appreciate any suggestions thanks
Old 05-28-2009, 11:26 AM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
Re: Autometer mech. speedo problem
Go here: http://jagsthatrun.com/Pages/SpeedSe...eedometer.html Check out those. I am using the same thing as #1 on my 91 with the same speedo. basically you unscrew the cable, screw on the adapter, screw on the cable and hook those two wires in to your VSS wiring.
Old 05-28-2009, 05:15 PM
Car: 86 Iroc-z
Thanks for your help i went on the site and ordered one,great simple solution
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
GTAman
09-14-2015 09:53 AM
middian
09-05-2015 01:42 AM
andy74
09-03-2015 08:41 AM
greenyone
09-02-2015 03:39 PM
Quick Reply: Autometer mech. speedo problem
