aftermarket shifter plate or console cover
Old May 29, 2009 | 04:53 PM
85camarojunkie's Avatar
Car: Camaro coupe
I dont know if this is an over asked question. I've been looking for a shifter plate cover, i have a B&M megashifter and i have cut the hole out for it but have seemed to break 2 covers already. So im looking to see if anyone knows were i can find a steel one or anything that dont have the ashtray or something aftermarket really. I just ordered the covan classic gauge cluster so im looking for a shifter plate along them lines or if anyone on the forums is good at machining and could do one would be great. Thanks in advance.
http://covansclassic.com/product_inf...products_id=12
Old Jun 1, 2009 | 09:09 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: aftermarket shifter plate or console cover
you can fabricate one out of a sheet of ABS, aluminum or steel... maybe find a local machine shop that would produce a design that you dimension for them.
Old Jun 1, 2009 | 08:10 PM
Car: Camaro coupe
made one out of thin piece of steel but may i add looks like shiz-nit. where can i get a piece of ABS plastic?
Old Jun 2, 2009 | 06:21 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
You can order several dimensions and thicknesses from McMaster.com. Here is the main section:
http://www.mcmaster.com/#abs-plastic/=251syj
They list it as smooth here, but search around because I could've sworn you could buy it textured too.
1992 Trans Am
May 10, 2023 07:19 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
colton_carlson
Mar 8, 2019 12:21 PM
rh76camaro
Exterior Parts for Sale
Aug 29, 2015 06:55 AM
NBrehm
Aug 25, 2015 11:49 PM
