T-top rubber grommet thingy
Old Jun 23, 2009 | 03:28 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
So I determined the cause of my one and only t-top leak. Where the locking pin comes out of the t-top there is supposed to be a little rubber grommet. I'm missing one and the other three have deteriorated, allowing the t-top to wiggle up and down causing a small leak, which destroyed my floor pan. So does anyone know of anyone that makes these things, or will I have to fab something up.
Alex
Old Jun 23, 2009 | 04:18 PM
1985blktransam's Avatar
Car: 1985 Firebird Trans Am
Engine: 5.0 Liter Engine
Axle/Gears: 3.08
Re: T-top rubber grommet thingy
Hi:
The only place that might have is :
http://www.eastcoastt-top.com/index.html
I plan on bring my TA there soon to have them redone. This is the closest place I could find who works on T-Tops. No one that I found in my area will touch T-Tops.
He also advertises Sales and service, so he may have the parts you need.
Rob
Old Jun 23, 2009 | 10:18 PM
Net-Viper X's Avatar
Car: 91 Bird w/Aero Pkg - 02 T/A Col Ed.
Engine: 5.0L - 5.7L Ram Air
Just curious, but what kind of car do you have, and are the T-Tops the Cars and Concepts type? My car has stock T-Tops on it and does not use grommets like that. The pins that hold the top on are below the weatherstrip and their is no way water could even get to them to leak unless the weatherstrip around the T-Tops was leaky. My car is a 91 model, and the replacement top I got for the passenger side was off a 92, and neither have grommets, or any need for them.
Edit: I meant Cars and Concepts type, dont know why California Customs poped in their.
Old Jun 25, 2009 | 08:04 PM
Here's some pics, they are below the weatherstripping. Water isn't coming through the pins. The pins don't keep the t-tops sealed to the car. The driver side isn't too noticeable but you can move the passenger side t-top up and down when it's locked in. Has about 1/4" of movement. It's the actual pin that's loose, not the hole it locks into. The first pic is of the front pin, the second pics is of the rear.
Thanks for the help guys
Edit: I honestly don't know what type t-tops they are
Attached Thumbnails T-top rubber grommet thingy-dscf0042.jpg   T-top rubber grommet thingy-dscf0043.jpg
Old Jul 2, 2009 | 11:28 AM
C'mon now, anybody?
Old Jul 2, 2009 | 10:01 PM
I see what you are talking about now. Thats a different type than I have, mine are the ones with the large plastic pins and it fill the entire hole, not needing that grommet. I saw something similar to that a while back, but it was for the 4th gen cars. It was called a t-top bushing, you might do a search for that and see what you find.
Old Jul 3, 2009 | 07:00 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
Only one leak? Lucky you!
there are 2 different t-tops for third gen's
If there is a vynil strip that borders the paint and the t-top, then it is not factory! (do not count the plastic edge on the t-top for this)
If the glass of the t-top has a little space then paint, then that is factory t-tops.
You would have to find out the manufacturer of the aftermarket tops, if you have them.
The photos you attached do not look like factory tops!
Send a photo of the roof of the car and I can tell you for sure. I run across both types in the wrecking yards
Old Jul 4, 2009 | 03:11 PM
Thanks for all the help guys. I do believe I have aftermarket t-tops. Which doesn't surprise me as the car is a salvage title so they probably shattered when it got hit. The tops have a vinyl strip around the edges which is wearing away. Not sure about the paint though, don't really see any. The last pic is of the inside of the top. I think I might just get new t-tops. I've heard that they make plastic tops. Is this true and is there any other benefit other than weight.
Thanks again
Alex
Attached Thumbnails T-top rubber grommet thingy-006.jpg   T-top rubber grommet thingy-011.jpg   T-top rubber grommet thingy-024.jpg
Old Jul 5, 2009 | 11:38 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Looks like you could just put a standard grommet on there.Should at leaset get rid of the looseness.
Old Jul 7, 2009 | 10:05 PM
Axle/Gears: unknown
plastic or acrylic t-top replacements have a habit or crazing over time.
More so in hot always sunny areas!
The frames on your car look factory!!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
Gordonr1973
Sep 29, 2015 11:59 AM
