water inside-passenger side!
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi , i have water inside on the passenger side carpet
...only if it rains or if i wash the car ...not prestone ..the heater core is new ..it is clear water ..i know these cars have a firewall seal problem ...but does anybody have a pic to see where it needs to be sealed?....thanks
...only if it rains or if i wash the car ...not prestone ..the heater core is new ..it is clear water ..i know these cars have a firewall seal problem ...but does anybody have a pic to see where it needs to be sealed?....thanks Joined: Aug 1999
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: water inside-passenger side!
Look through the screen at the bottom of the windshield. The well on the pass side may be rotten or full of debris.
JamesC
JamesC
Transmission: T5 WC
i have , but i can't really see anything ..put my hand in the wiper well and tried to feel around..i didn't feel anything rusty.....
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
If you look at the firewall in the engine compartment you will notice a seam that has been spot welded going horizontally. Sometimes you will notice streaks of rust running below this seam, but there is no rust visible!
Your firewall actually curves toward the rear of the car behind that seam. The factory then added the metal on top of that seam, leaving a "v" shape in that area where the wiper linkages reside. They filled that gap with some body sealer. That sealer is old! When it gets old - it cracks!!! Then the water gets behind the sealer and sits and rusts.
This seam goes right behind the evaporator housing! You can inspect this area by removing the cowling grill off. To look further down the sides you may use a mirror and a flashlight. This can rust through the firewall.
Have you ever seen a 60's mustang with a plexiglass sover over the vents between the wipers. They have the same problem - it is very costly to fix back to original, so they seal off the water. I fixed mine - but what a PITA!
Transmission: T5 WC
thanks for the info..but is this where the black metal piece (wiper area) meet the firewall?..behind the hood seal?...i noticed there some metal that's a little rusty..but it doesn't look like it would have water coming in from there....i have water coming into the passeger area..can't really see where it is coming in by,,i also removed the fan heater cover and no rust ...would you have a pic with an arrow where it may be ?..this is bugging me!
Car: 1990
Axle/Gears: stock
is it possible that when you have the vent open that you get water inside? could it be that the tubing going to the air vetns, etc are broken or have a hole in them, or are not conntected?
take a look - that about covers everything on that side to get clear water.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
feel the carpet and see where its coming from, the water will sit ing the low spot. Feel around the kick panel and over to the firewall. I had the same problem on the 92, it was a bad door seal. You could feel a wet spot under the kickpanel leading to the low spot at your feet,
Transmission: T5 WC
Transmission: T5 WC
the door seal ?..the one around the whole door ?..i think it might be the problem..i tried throwing some water near the wiper area and below the glass and no water came in ,,but when i had the leak i had the car parked downwards in the driveway and it rained quite a bit ,,,a bad door seal would make sense ..you know where i can get some?
ambainb
Apr 25, 2016 09:21 PM
toronto formula
Nov 10, 2015 06:17 AM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
