shifter knob swap
Old Jul 17, 2009 | 07:04 PM
lwms135's Avatar
Car: 1986 IROC-Z28
Engine: 5.0 TPI
Axle/Gears: Factory axle,and gears
shifter **** swap
Can you replace an 8 ball style shifter with the push down button,with an square shifter with the square button on 86 IROC with no problems?
Old Jul 17, 2009 | 07:28 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: shifter **** swap
You will have to replace the entire shifter, not just the handle. The way that they mount is different.
Old Jul 22, 2009 | 04:40 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Or you simply grind a notch so that a snap ring can be applied.
1992 Trans Am
May 10, 2023 07:19 PM
BewleyBizzIROC
Feb 3, 2020 09:52 AM
camaro11j
Sep 19, 2018 08:49 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
NBrehm
Aug 25, 2015 11:49 PM
