Third Gen Firebird Console Swap Info
Old Oct 19, 2014 | 12:09 PM
  #51
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Re: Third Gen Firebird Console Swap Info
no trimming required
Old Oct 19, 2014 | 01:04 PM
  #52
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
Axle/Gears: 3.27 9-Bolt
I'm waiting on some parts to slip the tranny in, but doing a dry run with the console it looks very close?
Old Oct 19, 2014 | 01:11 PM
  #53
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
Did you cut the little triangle piece that sticks out from the front of it? I think that gives you about 2 more inches to slide it up.. Mine didn't come with it though..?
Old Oct 19, 2014 | 01:14 PM
  #54
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
Triangle piece of plastic?
Old Oct 19, 2014 | 01:16 PM
  #55
Veaceonee's Avatar
I think he means the "horns" that stick out the front. You need to cut those off.
Old Oct 19, 2014 | 01:18 PM
  #56
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
Ok, that's easy enough
Do the Hurst shifters give you any extra clearance?
Old Oct 19, 2014 | 01:48 PM
  #57
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Yes, triangle was wrong word to use I guess.. but ya if you clip that off you get an extra inch or two which looks to be exactly what you need!!
Old Oct 19, 2014 | 05:44 PM
  #58
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
I think those tabs hold the shift boot in place.
Do you think if it is holding everywhere else it will hold it in place well enough?
Old Oct 19, 2014 | 05:48 PM
  #59
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
I have no idea what you are referring too, but what I am talking about doesn't involve the shift boot. Let me edit a picture real quick.
Old Oct 19, 2014 | 05:49 PM
  #60
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Old Oct 19, 2014 | 05:50 PM
  #61
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Like I said, if you cut the piece off I circled in red, it will allow you to push the console up around 2 more inches.
Old Oct 19, 2014 | 06:42 PM
  #62
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
I don't have that piece. I'm tight up against the radio pod.
Old Oct 21, 2014 | 07:39 AM
  #63
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Hmm, Sorry I am not much help then, I have a automatic trans.
Old Oct 26, 2014 | 07:12 AM
  #64
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
It all works out...
The fourth gen console fit perfect around the cut out in the tunnel.
I have a finger or two in the front to spare! I didn't take the time to look at the donor car with the third gen console but I suspect it's about the same.
Old Oct 26, 2014 | 01:54 PM
  #65
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Holy tall shifter batman...
Old Oct 26, 2014 | 02:12 PM
  #66
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
Right!
I've already placed an order to remedy that Viagra malfunction.
Old Nov 4, 2014 | 05:06 AM
  #67
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
MUCH better!!
Attached Thumbnails Third Gen Firebird Console Swap Info-103912.jpg   Third Gen Firebird Console Swap Info-104239.jpg
Old Apr 14, 2019 | 04:39 AM
  #68
gavin.priestley's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 V8, TBI
Originally Posted by theimpaler68
actually the thirdgen camaro console will fit with the slightest trim job to the top. i know this because i have one in my 88 t/a
I know this is an old post but I’m fixing to do this tomorrow morning using a third gen camaro console that’s going in my Firebird. I’ve always thought the camaro consoles looked better to be honest. But what is that “slightest trim job to the top” mean? What has to be trimmed?
Old Apr 7, 2020 | 06:17 PM
  #69
sparky87GTA's Avatar
hey there, how did you make out with that swap? I’m looking at doing the same this week! Anything to take note of?
Old Apr 7, 2020 | 06:42 PM
  #70
Engine: 305 V8, TBI
hey and it went just fine, I had to trip about an inch off the top of the bezel so that it could clear the dash and ac vents. I’ll post pictures.
Old Apr 7, 2020 | 07:02 PM
  #71
Looks great! What tool did you find was easiest to cut the plastic?
thanks eh!
Old Apr 7, 2020 | 09:08 PM
  #72
Engine: 305 V8, TBI
thanks eh!
hey thanks! I could’ve done better but the other console was nasty 💩 and I just used an angle grinder 🤘🏽
Old Aug 4, 2021 | 02:53 AM
  #73
JayceRamey's Avatar
Has anyone tried putting a 3rd gen camaro center console inside of a firebird? the rubber inside my 1989 firebirds center console is giving out and my friends camaros (1992) center console is plastic and has a cleaner look to it so I was curious as to if i could put a camaros in a firebird.
Old Jun 28, 2023 | 10:09 AM
  #74
Badbird33's Avatar
Hi, how much did you have to trim off of the camaro console? I'm going to be swapping a blue carpeted center console into my 84 trans am, so i am looking for a rough estimate of what i need to do and if it will bolt right in. Also were you able to use a trans am top half of the console or did you have to use a camaro top? Thank you.
ZTM87Firebird
Jan 11, 2012 07:37 AM
92formula12
Jun 21, 2010 11:55 AM
Firehawk505
Mar 6, 2003 11:50 AM
maverick544
Jan 12, 2003 11:57 PM
TransAm87
Jun 2, 2002 03:22 AM
