93-97 TA Gauges v6 in a v8(83 TA)
Old Aug 5, 2009 | 08:39 PM
Kenshinx's Avatar
I'm doing a swap and get most the wiring hooked up and notice that the tach at idle is 1.5k, and then realized the cluster is for a v6. Is the connecter in the back the same on the V8's as the V6's and will changing it correct the incorrect reading. Also has very bad response. its drops slow and hangs so when im realy at idle it is still falling from 3k. I looked for a adjuster on the cluster and there doesn't seem to be one unless someone knows a trick. Any help would be wonderful
Old Aug 7, 2009 | 12:39 PM
90_T/AGTA's Avatar
Car: '90 GTA
Re: 93-97 TA Gauges v6 in a v8(83 TA)
You need a LT1 cluster. the connector plugs are the same
Old Aug 8, 2009 | 06:48 PM
Kenshinx's Avatar
Thanks couldnt seem to find a straight answer for the connectors anywhere.
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tcflint
Sep 27, 2015 05:58 PM
