grant steering wheel HELP!!
Old Aug 6, 2009 | 09:48 AM
joey 350 LT4's Avatar
Car: 1991 1le 5.7 6 speed
ok i hav in stalled a grant steering wheel on my 91 formula but heres the deal i cut the collar back casue it was rubbing but now the steering when turnd all the way to left or right it trys to click the turn signal and it sounds like its crushing something in the colume, and its got tight spots where its really stiff to turn and its got a lose spot where it will jump about and inch in either direction reall fast..... car was air bag going to take it off 2 day and check just want to know if maybe i some destroyed the colum somehow thanks
Old Aug 13, 2009 | 12:26 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
Re: grant steering wheel HELP!!
i would like to know too
Old Aug 13, 2009 | 12:59 PM
fullcircle's Avatar
Car: 91 RS
Engine: 355, vortec heads, carb
Transmission: 700
Axle/Gears: 3.42 posi
Went through the same thing with mine. Removed the clock spring, and it works fine. No more clicking, and grabbing the turn signal. The clock spring is held in place with a small snap ring aroun the main shaft. You can unplug it under the dash and pull the pigtail out with it, or just cut the wires.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
