fiberglassing my headliner, lots of pics.
Old Sep 2, 2009 | 12:47 AM
popballz's Avatar
Car: 89 firebird
my headliner was pretty bad, it did not look all that bad in the car, but both front sides were ripped off, almost ripped in half(now it is), and the backs by the seat belts are pretty bad,
so here is how far i am,
those clamps were for when i do that side, there is pieces missing.
i scraped the actual headliner off of it, its too strong with out it! and i planned to put a layer on this side too.
Old Sep 2, 2009 | 12:48 AM
popballz's Avatar
Car: 89 firebird
Re: fiberglassing my headliner, lots of pics.
does anyone know if this is how the ends are shaped?
i am not sure, both my sides are gone, a picture of one would be really nice!
its a nice little project, and while it is drying its a good time for me to make room in the garage for my car!
Old Sep 2, 2009 | 01:17 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I have to hand it to you, that's coming along pretty good for what you have to work with. But it might be time for one of these: Link
Or could try finding something from a junk yard.
Old Sep 2, 2009 | 04:18 PM
popballz's Avatar
Car: 89 firebird
yes, yes i know, but i didn't really want to spend that much on it now, i might have to if this does not work out, but i think mine is coming along pretty nicely!
for some entertainment, a pic of my other car!(i have two)
Old Sep 2, 2009 | 05:13 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
If i hadnt just bought a headliner i would fiberglass mine
Old Sep 2, 2009 | 09:11 PM
Scorpner's Avatar
Engine: V6, V8
Maybe I should be thinking more like you. It's something you can't see anyways and if you have the skill, why not?
Save it for performance mods instead!
Old Sep 3, 2009 | 09:37 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Keep the pics coming. Mine is very flimsy but I believe I have all the pieces. I am not to that part of my project but I am going to try fiberglassing mine. I figure its worth a try and if I screw it up I will not have put out a lot of cash. Then I will just get a new one.
Old Sep 3, 2009 | 11:20 AM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
keep us updated, i was thinking about doing this to mine as well, and would like to see how yours turns out, looks good so far
Old Sep 11, 2009 | 05:22 PM
popballz's Avatar
Car: 89 firebird
Old Sep 11, 2009 | 05:23 PM
popballz's Avatar
Car: 89 firebird
Old Sep 12, 2009 | 06:23 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
My headliner is made from 3-4 different headliners only difference is with my approach I bonded the pieces with long strand fiberglass filler before the resin. Why apply the fiberglass on broken chunks? It makes more sense to make the headliner one piece again and then start glassing.
Old Sep 13, 2009 | 01:07 AM
popballz's Avatar
Car: 89 firebird
i am/was missing a few pieces, and it is pretty easy to use some cardboard/duck tape to fill in the spots.
and if you got both pieces, its easy to fiberglass them together, i also am going to scrape off almost all of the actual headliner material so that when i put the fabric on, it has something more solid to stick to.
Old Sep 17, 2009 | 10:29 AM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
I am going through similar process with coupe headliner. Yes you will need to scrape off old foam. I found that my fingers worked best intially and then followed up with a stiff brush. Don't go too hard or you will damage headliner (unless the resin the cr*p out of it). I bought high temp adhesive from Autozone, comes in orange can with blue cap. Stuff works good but becareful when spraying. Adhesive is like spiderwebs and shoots all over! You can't remove glue if it gets on good side of headliner fabric.
Also, I tired using stock interiors to order fabric since they are one of the few that sells by the yard. They initially sent me wrong color. They then sent me three more rolls that were damaged since fabric is wrapped around cardboard tube and wrapped in plastic. Tubes were bent and fabric creased. If you don't care about matching existing color 100%, Joanne Fabrics has headliner fabric with foam backing for cheap. I am going to use classic industries as they have exact colors.
BTW, I have huge roles of dark charcoal and medium grey if you need it.
Old Oct 23, 2009 | 10:01 AM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
How did this project turn out? I thought I had my hands full when mine broke into three pieces. I was able to fix mine with just a bit of glassing in the weak areas and put resin on the entire back side for additional strengthening and waterproofing.
Have some pics of the project at http://www.mentalsocket.com/iroc87/headliner.html
Old Oct 23, 2009 | 08:41 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Popballz, did you finish headliner?
ZZ3astro, finally finished my repair. Have some dimples in headliner but overall happy with results. Glad to see that severely damaged boards like yours and Pops' can be repaired. Good work!
Made tutorial here
https://www.thirdgen.org/forums/inte...rial-many.html
Lanz06
Mar 13, 2019 06:07 PM
MORREALE5
Sep 13, 2015 09:01 PM
Nick McCardle
Sep 10, 2015 08:36 PM
blackbmagic
Interior Parts Wanted
Sep 8, 2015 10:36 PM
