92 z28 dash in 87 z28
Old Sep 6, 2009 | 04:09 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i cant seem to find any articles about this. i want to swap this all i found a parts car for 250 it has the 92 145 speedo and mint z28 dash and was wondering what do i need to take out in order to do this swap o and the cars not a real z its a 6 cylinder with all z28 options like posi and iroc rims the 145 speedo and z ground effects. idk if this makes any diference in the swap but let me know please
Old Sep 6, 2009 | 10:23 AM
cdoyle's Avatar
Re: 92 z28 dash in 87 z28
To swap the 91/92 style gauges into any other 3rd gen you're going to need to swap out the entire dash. You'll also need to repin the 91/92 dash to work with your 87. There are wires on C-100 (firewall) that will need to be moved around, and also on the computer harness (can't remember the id of that one).
I put a 92 dash in my 84, do a search on here for the thread on it.
It's really not that hard overall, just need to get the diagrams for the harnesses so you can match up the wires.
Old Sep 8, 2009 | 01:27 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
what about the speed sensor. also as of now my oil pressure and water temp are not working on the stock cluster their run to autometer guages. i dont need them. if you find the diagrams and anyother problems you had can you send me the link.
Old Oct 2, 2009 | 12:56 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
youll also need the actual dash mounts out of the 92, as the 90+ uses a different style mount
MantyZ28
Nov 8, 2015 06:54 PM
383cam
Sep 9, 2015 06:01 AM
Stryker412
Sep 7, 2015 09:11 AM
Ian Irvine
Sep 4, 2015 08:08 AM
andy74
Sep 3, 2015 08:41 AM
