Do they make custom auto shift knobs?
Old Sep 10, 2009 | 08:14 PM
xxiamdrewxx's Avatar
Car: 86 Berlinetta/84 s15
Do they make custom auto shift *****?
Hey all my car didn't come with a shift ****. Its an automatic and I cant seem to find any custom shift *****. I personally don't like the stock **** for the automatics that these cars come with so I was just curious. Thanks a bunch everyone.
Old Sep 10, 2009 | 08:18 PM
aciddrop2804's Avatar
Car: 1984 camaro Z28
Engine: 5.0L H.O. L69
Re: Do they make custom auto shift *****?
I think you would have to buy a whole new shifter assembly
Old Sep 10, 2009 | 08:26 PM
Bummer that's lame are there any other shifter kit's other than B&M?
Old Sep 10, 2009 | 10:28 PM
only thing I can find is the b&m mega shifter. its not that expensive and I'm pretty sure a lot of people on here use it.
If you have the funds and know how i would recommend switching to a manual trans or at least a better auto like a turbo350 or something.
Old Sep 10, 2009 | 11:27 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
hurst makes one too i think
Old Sep 11, 2009 | 12:04 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i have an auto and i have a manual shift **** on the stock shifter. its the kind that uses the sleeve and set screws to stay in place, rather than the typical threaded type. its nice and solid too, doesn't move around. i got it @ autozone for like $25.
the one i have:
http://www.pilotautomotive.com/Produ...7954&PCID=1102
it has LEDs, but i dont ever use them. you can't tell unless they're on. i only got it bc it was black, it matched my interior, and it looked better than the stock shift ****.
Old Oct 11, 2009 | 08:12 PM
Big Cleatus's Avatar
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
If you use a manual **** on a stock auto shifter how do you get away without the park release button?
Old Oct 11, 2009 | 08:34 PM
Chevy8588's Avatar
probably disconnected the shift interlock cable
Old Oct 12, 2009 | 12:17 AM
1984_350_lt's Avatar
Car: 84 z28
WHEN I INSTALLED MINE THEN **** HELP THE RELASE BUTTON DOWN.
BUT I ALSO FOUND AT AUTOZONE A PISTOL GIRP SHIFTER THAT REALLY LOOKED LIKE THE BUT OF A PISTOL AND HAD A TRIGGER THAT YOU PULLED TO RELEASE LET SHIFT RELEASE IT PRETTY COOL. GOT IT AT ADVANCED AUTO FOR 25 BUCK I THINK. I'LL TRY TO POST A PIC FOR YA
Old Oct 12, 2009 | 01:10 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
http://www.amazon.com/gp/product/B000BRFG3S
Old Oct 12, 2009 | 03:04 AM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Originally Posted by ellocojorge
Im soooo getting it
thats soooo sexy
reminds mee of the "vanishing point" white Dodge Challenger.(my all time favorite car along with 3d gen Trans am) =]
Old Oct 16, 2009 | 10:06 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Momo makes a stylish automatic shift **** that would work. You might also look into newer oem shift ***** from different cars (GM & otherwise).
Old Oct 17, 2009 | 09:13 AM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
I did something a little different. I took a manual ****, put a plastic insert in between the **** and the stick, actually I cut it down quite a bit too. It could slide off yeah, but its actually a good balance between being tight and being able to move. To put it into gear, you push down on the ****.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
