Waterproofing T-Top Headliner Bottom?
Old Sep 28, 2009 | 09:30 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
I was wondering if anyone has ever done, or heard of, applying some sort of protective layer over the t-top material? Not the colored fabric that is seen, but rather, the yellow underside.
I'm finishing up a 100% interior restoration and would like to do preventative maintenance in case of future t-top leaks.
Old Sep 29, 2009 | 07:49 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Waterproofing T-Top Headliner Bottom?
a lot of people when restoring the fiberboard headliners use fiberglass to make it a bit stronger. This would also be a decent choice for waterproofing if your headliner is in good shape. However, if you still have the cloth on it (the part that shows), you may end up getting resin soaking through and ruining the appearance.
may be able to try beadliner as well, but kinda think that may soak through as well.
Old Oct 7, 2009 | 08:22 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates?
Old Oct 9, 2009 | 08:29 PM
5speed's Avatar
Car: 86 IROC
Transmission: 5 speed
Axle/Gears: limited slip
I replaced my extremely worn out, sun rotted head liner with an abs one. Looks factory and no more worry about water ruining it.
Old Oct 9, 2009 | 08:50 PM
KITT1983's Avatar
do you have any pictures of it and the install? how did it fit?
Old Oct 19, 2009 | 07:57 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
I just did my ttop headliner this week. When I removed it, it ended up in three pieces! I have the overhead console so there is not much material to work with because of the cutouts. I was able to piece it back together with 5 min epoxy and then laid glass and resin across all of the weak spots. When I finished that, I decided to put resin on the entire surface of the inside (where the water would land on it). Also stiffened up the whole thing a bit. I didn't bother coating the underside though.
Overall it turned out nice. Still need to install it but I want to check the hatch bolts while it's still out as I think one of them might be leaking.
Old Oct 19, 2009 | 08:04 PM
KITT1983's Avatar
do you have any pitcures?
Old Oct 19, 2009 | 10:18 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Yeah I took a bunch while I was doing the resin work. I didn't take any during the headliner material installation (another story in itself). I'll upload them tonight and put a link up for you.
Steve
Old Oct 20, 2009 | 12:42 AM
ZZ3Astro's Avatar
Car: 87 Iroc
Wow what a pain! I haven't edited anything on my site for about four years. Finally decided to start using it again. Forgot how long it takes to make a page with some photos and info. Anyway here is my page on the headliner work:
http://www.mentalsocket.com/Iroc87/headliner.html
Old Oct 20, 2009 | 06:44 AM
KITT1983's Avatar
awesome craftsmanship dude
MrPackstin
Oct 25, 2017 08:09 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
