Manual Shift Booth On Automatic?
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Manual Shift Booth On Automatic?
I have a scientific brain! jk.It just depends on who you ask, but here's how i did mine.I started by cutting the slider & surrounding plastic out.The cut out is the same length as the indicator window.The width is as wide as i could go, 1/4 from edges on each side of shifter.I cut 2 pieces of hanger wire long enough the run the edges of the boot opening.Bend both to the same dimensions as the boot opening, solder or weld the ends.Stitch the bottom of the boot around one of the hanger wires.Stitch the 2nd about an inch lower.The 2nd one keeps the boot from snagging on the shifter mechanism.the 2nd wire should be cut a little longer since it requires a bend at the front(see pic).This bend is so the shifter wont push the boot out of place when in "park".
The right side of the boot is held in place by the top of the console.When the
shifter bezel is re-installed.
Heres a back view.The left side required me cutting part of the indicator housing(white).Where it butts up against the boot.This is what holds the boot inplace, along with a little silicone.The pics dont really show this though.
As it looks today
As it looks today
Engine: 3.0L 2JZGE
Hey Rick,
Dude thanks for the pictures and the instructions thats the perfect way to explain everything.
Thanks. Tony.
Thanks. Tony.
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Ok, strange question but how did you get where you cut out to look so straight. What did you use to cut it?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Good question.I used a ruler & an exacto knife to mark my line (from the underside)for the edges.I made the rough cut with a dremel too, to about 1/16 from the marked line.From there i used a course file & worked down to a finer file.I finshed it with some 600 grit sandpaper.
Be careful filing on the corners.Its easy to go too far.
Car: Trans Am
Engine: V8 350 TPI
hmm its starting to look easier now that i got a better look at it(i was on my iphone at first, now on the comp).
im definitly gonna give it a try. its gonna be hard tryng to get those hangers together im gonna have to figure out another method to do this..
maybe crazyglue the boot to the underside of the shift plate and just let it hang up the shifter from there?
idk
but any who 84 1le thanx for the post.btw ur camaro looks super tough!!
idk
Engine: 3.0L 2JZGE
Tony.
Car: Trans Am
Engine: V8 350 TPI
i would paint my camaro all black but out here in arizona darker colors get dirty so fast from the nasty dust winds..
i have to wash my nissan maxima like every 3 days in order for it to look clean..n since ive had my camaro i havent washed it lol.i dont care for that car anymore
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
I attached my boot similar to 84 1LE, except I used a staple gun and gorilla glue. Heres a pic of mine with the HURST handle. I push it down to shift.
Engine: 3.0L 2JZGE
Anyways umm I was at my local JK and they have a 5 speed shifter plate and my buddy there is letting it go for me for 20. He told me someone else he would sell it for 40. But it has a lil crack on one of the bold holes so i'm not sure if I should go with you guy's mods or with a 5 speed one.
Thanks. Tony.
Car: 87 GTA
Remember.....You asked!
Please tell me the blue is a camera malfunction, or a Photoshop joke......
its blue. i want to put some color in my interior. i prefer an offset interior than a plain full black interior. i might go with a black boot afterwards, but i got the boot and shift **** as an xmas gift.
The home grown two tone almost never looks good... It's usually just too obvious that someone removed a panel and painted the entire thing a contrasting color... It always looks like the San Francisco treat. It's not my preference, but if you like it, more power to you.
once everythng is put back together and in sunlight ill take better pics. it looks alot better in person. besides the color, how about the 5 speed look? remember theres a megashifter under the boot not a factory shifter
Car: 87 GTA
I think the blue of the console make the shifter indicator stand out too much. Maybe with a blue lens with lettering & only the letters lighting up?
im most likely going black boot. once im 100%done with fitment and im ready to finalize everything, then ill probably go black boot. theres not much blue in the interior. just enough to give it some color.
Car: Trans Am
Engine: V8 350 TPI
Look how much it hangs over though..I think if there's no blue in ur interior u shouldn't let that be the only blue piece u carry in there..IMO it looks cheap I think a nice shiny black will set that off real nice my GTA come stock with a shift boot n I love it cus I didn't have to invent some bs lol..I was thinking about it before when I had my camaro bit I got rid of it..
over the front? thats because its covering the t-handle that is used to allow you to put it in gear. i didnt want to expose the handle because i wanted to make it a 5 speed look. heres a pick of it with the original megashifter setup to show what im talking about.
Car: Trans Am
Engine: V8 350 TPI
That looks way better..has a nice racing look to it..if there was blue at all n it was dark grey or black I wud say u have a clean *** interior..
Engine: 3.0L 2JZGE
Engine: 3.0L 2JZGE
https://www.thirdgen.org/forums/inte...automatic.html
Tony.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
84 TA NV
Sep 6, 2015 08:02 PM
