86 speedo
Old Oct 29, 2009 | 05:08 PM
placoo12's Avatar
Car: 1986 trans am w/ lt1 swap
Engine: Lt1 baby
Axle/Gears: Stock
86 speedo
Is my 1986 trans ams speedo cable driven? I have a lt1 swap that I just bought and the speedo doesn't work. It does twitch when I shut the car off. The guy also said that it did work before he swaped the engine. The tranny is a 700r4. So any suggestions on how to fix the speedo are highly apriciated.
Old Oct 29, 2009 | 05:58 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 86 speedo
No, electric. Swap in an electric VSS and you should be good to go.
JamesC
Old Oct 29, 2009 | 06:29 PM
placoo12's Avatar
Engine: Lt1 baby
Axle/Gears: Stock
Re: 86 speedo
Do you know where I could order one of those.
Old Oct 29, 2009 | 08:32 PM
JamesC's Avatar
Re: 86 speedo
You might phone the following company:
http://www.transmissioncenter.net/sp...n_______va.htm
JamesC
Old Oct 29, 2009 | 09:01 PM
JamesC's Avatar
Re: 86 speedo
BTW, did the previous owner eliminate the ECM? If so, your problem lies there.
JamesC
Old Oct 30, 2009 | 10:27 PM
placoo12's Avatar
Engine: Lt1 baby
Axle/Gears: Stock
Re: 86 speedo
I'm not to sure. Is there any other signs to tell if he did.
Old Oct 31, 2009 | 07:02 AM
JamesC's Avatar
Re: 86 speedo
Remove the pass side hush panel and take a peek to be absolutely sure. The wiring from the ECM comes into the engine bay on the pass side through the fender. However, it's absence may only mean that the wiring has been hacked.
JamesC
Old Oct 31, 2009 | 09:16 AM
placoo12's Avatar
Engine: Lt1 baby
Axle/Gears: Stock
Re: 86 speedo
Ya I found out that he did eliminate the factory ECM and used the lt1 instead
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
