Gloss or satin black spray for trim/dash?
Old Nov 8, 2009 | 07:51 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
I've tried searching but didn't get a lot of results. I have an old b-panel trim piece along with dash pad that needs to be resprayed black. I am not sure what would match stock look best, gloss or satin black. Window trim pieces seem to have a gloss finish to them but I think that gloss spray paint would probably look too shiny. Also I read on other dash repair threads that gloss spray on dash would be bad due to excessive glare. I'm thinking satin black is what I need but looking for some opinions. Also, do I need vinyl spray for dash or is any plastic spray ok? Thanks!
Old Nov 8, 2009 | 09:26 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Re: Gloss or satin black spray for trim/dash?
SEM Landue Black. I used it and its GREAT!
Old Nov 8, 2009 | 11:26 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I think satin black would be your best bet, gloss will be too shiny. Vinyl spray should work fine, but make sure the part is super clean first. I like to wipe down plastic pieces with mineral spirits before spraying, to remove any remaining dirt or oil.
Old Nov 8, 2009 | 11:34 PM
Wolnam's Avatar
Car: 87 Camaro Sport Coupe/ 89 GTA
Engine: 2.8L V6/ 5.7L 350 TPI
Go with satin. I just finished the interior in my car and sprayed it satin. Its a great match
KRYLON makes a spray called FUSION......is specifically made for spraying plastics. It worked for me .....check out my garage and you ccan see the pics.
Old Nov 9, 2009 | 12:47 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Thanks for the replies! Martin Landau black? I googled SEM Landau and it seems a favorite choice for interiors and has the right amount of "glossyness" http://www.chevelles.com/forums/showthread.php?t=179586
I'm going to pick up some Landau since I need SEM texture paint too. My rear hatch sunshade is badly faded to purple. Looks like I can spray fabric with Landau too.
Old Nov 9, 2009 | 05:31 PM
ShMaCk2004's Avatar
its SEM Landue Black Color Coat
Old Nov 12, 2009 | 06:33 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
I used spot puddy and went over it a couple times until the crack was gone then sprayed it with rust-oleun undercoat. Didn't spray anymore area then where I fixed it. It was a perfect match in color and texture.
Old Nov 16, 2009 | 01:26 PM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Transmission: Automatic
Would anyone know the sem color for trim in our gray firebird interiors?
Old Nov 16, 2009 | 02:02 PM
thecraze's Avatar
I agree with everyone else here about the satin finish. Only because gloss will be too dangerous for the dash pad. At the right angle while it's sunny, a gloss dash pad will cause a bad reflection on your windshield making it hard for you to see.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
m00n420
Sep 11, 2015 02:39 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
