tachometer off
Old Nov 9, 2009 | 07:25 PM
drewman_93's Avatar
Car: 89 Camaro
Engine: 2.8 V6
Axle/Gears: 3.42 open
tachometer off
The tach on my camaro is off by like 500 rpms at idle and it gets worse as it goes up, like i have a 2.8 v6 and my tach will pin at 7000 and i still have rpms to go. Is my tach bad? is there some sort of adjustment? did my grandma who i got the car from have it rebuilt with 8000 rpm capabilities? probably that last one. what do you guys think?
Old Nov 14, 2009 | 01:51 PM
mreld3r's Avatar
Car: 1986 Iroc, 89RS
Engine: 350 tpi, 350 tbi
Transmission: 700r4,700r4
Axle/Gears: 4.10,2.73
Re: tachometer off
https://www.thirdgen.org/forums/elec...aayyy-off.html
Try this one, found using the search button.
There is another thread about the resister pack on the tach's going bad.
I had to fix the resister pack AND the capacitor to fix my tack. It was reading WAY off (resistor pack) and then it was only a little off (capacitor fix).
Hope this helps,,,
BTW...almost all third gens have at least one of these problems.
Your problem sounds like the resistor pack.
toones
Jan 6, 2016 06:00 PM
ChevyZ71
Aug 13, 2015 07:30 AM
99Hawk120
Mar 13, 2002 02:24 PM
