Rear defroster wiring
Old Nov 15, 2009 | 02:49 PM
RodneyV's Avatar
I am needing help with my rear defroster on my 87 IROC when I bought the car the rear window grid was all cut up so I bought a new rear window with the defroster and now I can not find the wires to hook this up the window has 2 leads coming off of it I hook them up to the bottom of the strut but I can not find any wires coming from the car just wondering if I could see some pics of one hooked up or if someone could help me figure this out?
Old Nov 15, 2009 | 04:19 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Rear defroster wiring
if your car came with defrost stock, there should also be little wires at the base (where the struts attach to the car) that connect to the struts. I'd check under the plastic, they probably just fell back in there...
Old Nov 19, 2009 | 04:33 PM
RodneyV's Avatar
I have taken all the plastic off and can not find the wires. Which side or on both do the wires hook up any idea on where they come from under the dash?
Old Nov 20, 2009 | 05:06 PM
88camaroluvr's Avatar
check under the carpet by the back seat. it runs up the side and can get underneath the carpet. it is a black lead with a black elbowed connection on the end.
Old Nov 21, 2009 | 08:42 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Does anyone know where I can get the relay for the rear defroster? I can hear the relay behind my "performance suspension" badge click when I push my defroster button, can't find the relay anywhere. All the wires are connected.
Old Nov 22, 2009 | 02:42 AM
Has anybody had any problems with getting new hatch struts and then the wire from the glass defroster to the strut is too short now? Just the drivers side on mine is too short, wasn't a problem before. I will probably just have to put an extension on the strut to reach it. Any other ideas?
Old Nov 22, 2009 | 09:21 PM
HCR13's Avatar
Car: 1987 Trans Am
I think I had that problem once (too short) I think I just got some pliers and just "flattened" out the piece on the strut to extend it a bit.
Old Nov 23, 2009 | 01:49 AM
I tried that once but it can't bend very far without hitting the cylinder part of the strut.
Old Nov 30, 2009 | 03:04 AM
1904's Avatar
Car: 86 Trans am, 98 S10
Engine: 5.0 TPI
a
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
