seatbelt trim won't fit back together
Old Nov 21, 2009 | 07:00 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
I pulled apart some of the interior trim in my 1991 trans am. The plastic piece over the seatbelt mount will not fit back properly. Either the piece will properly align over the seat belt, and leave a gap between the piece and the outside wall of the car. OR, it will fit flush against the outside wall, but the seatbelt plastic portion will not fit through.
Some of the foam has dry rotted, and I will replace that, but I don't think that is causing any issues with fitment.
Any ideas?
Thanks,
Bill
Old Nov 22, 2009 | 10:41 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: seatbelt trim won't fit back together
I'm not following what you're saying, which seat belt? front back, bottom top mount, maybe some pictures?
Old Nov 22, 2009 | 03:53 PM
wgripp's Avatar
sorry about that,
Im referring to where the rear seat belts goes inside the plastic trim in the trunk.
Old Nov 22, 2009 | 09:20 PM
HCR13's Avatar
Car: 1987 Trans Am
hhmm, try to get a pic, I know there are a few plastic screws that are supposed to keep all the hatch plastic trim pieces flush to the outside wall. Are those in place? They are pretty huge plastic screws, you should see the holes around the edge. I say bolt up the seat belt covers then try to close the gap with the plastic screws. If this doesn't work, take a pic for a better look (for us)...
1992 Trans Am
May 10, 2023 07:19 PM
lee01
Apr 9, 2016 01:56 PM
justin57
Aug 20, 2015 07:05 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
slade5612
Aug 11, 2015 07:19 PM
