quick gauge cluster question
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
I have a 1985 Trans Am with a Chevy 350 carb in it, lots of go fast parts. the speedo only goes up to 85, I can get it up to 85 in like 3rd gear [ 5 spd trans]
how can I change the speedo to something like a 145? do I have to change the whole gauge cluster?
can i buy an aftermarket gauge and put it in? even thou there is a circuit board thing on the back of the cluster?
any help would be much appreciated.
Car: 1991 Chevy Camaro RS w/t-tops
Engine: BBC 396 .090 over (414)
Transmission: LS1 T-56
Axle/Gears: Shortened Ford 9, 3.25, discs, posi
Re: quick gauge cluster question
I know Auto Meter is has a good reputation for gauges and for 82-89 Camaros they sell a gauge and panel combo with Covan's Classic. I don't think they made one for your year Firebird. I'd check the size of the gauges and see if you could get like a 160 speedometer from Summit Racing. What I've done with a problem is to call Summit and talk to someone long enough to have them find a few gauges.
GOOD LUCK!
GOOD LUCK!
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
You can swap out just the speedo or the cluster. Some of the clusters may be different for different years so you could check the difference in the pin outs to be sure.
I'd check like ebay. I'd bet you can buy one pretty cheap new used or refurbished from a firebird the same year. Theres lots of stuff out there. As a backup try craigslist, but I'm not real fond of craigslist. Or if you didn't already, post something in the parts wanted. I'm sure between those you can find a speedo
Car: 1985 trans am
Transmission: 5spd
yeah, I think ima just buy an aftermarket one, would an aftermarket one fit in place of the stock one inside the cluster ? and use the same speedo cable?
Umm thats a good question. I'm more of a mechanical than cosmetics guy. I would say yes. You can buy speedometers that are cable driven. The main thing you need is the gauge diameter. Its probably 3 3/8 as a guess. Its a common size.
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
I just bought a 160 mph speedo from Street side for my 86. It is a 3 and 3/8 cable drive. I'm doing a custom autometer set up. However they carry dozens of different types, electric and mechanical. Just click the link below and then click the face style you are interested in and it will give you a bunch of options.
http://www.streetsideauto.com/catego...638&brand=BDHZ
Check Summit Racing's website too it might be a little cheaper.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
no aftermarket gauge will fit directly in the stock pod. And your 85 has a cable driven speedo. With some work you can convert to an electric speedo signal and use a 86-92 stock 145mph gauge
Car: 1985 trans am
Transmission: 5spd
didn't really want to do anything electrical, I think I am going to just throw in an aftermarket 160 speedo and make it fit
Engine: V6, V8
If that's the direction you want to go, some people have done some really nice aftermarket Firebird dashes on here if you do a search.
Car: 1985 trans am
Transmission: 5spd
well im not doing the whole dash, just the speedometer, but I am gonna try and make it look somewhat stock, like im going to keep it black with white #'s
Let me know how it goes. If you can post a finished picture. I have a Firebird in the shop that needs some electrical work
Car: 1985 trans am
Transmission: 5spd
cool. I am actually soon going to start rewiring my whole car. the wiring in this car is horrendous.
Me too. I'm doing a BBC carb'd swap so I'll probaby save like 20 lbs of wiresno joke.
Car: 1985 trans am
Transmission: 5spd
ha, im gonna be taking out 20 pounds of wires too. because mine was swapped to a carbed 350, like i said, anyways they left in all the ecu and all that ****. and they added a buncha ****, its horrible.
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
Go digital... My Speedo goes up to 300
haha...
haha...Last edited by C-Titan; Nov 28, 2009 at 12:16 AM.
Car: 1985 trans am
Transmission: 5spd
im kinda on a budget, and a whole brand new digital dash over a speedo isnt in that budget. haha
Car: 1985 Pontiac Trans Am
Engine: 305TPI
If only they made one of those clusters for the Firebird/Trans-AM I'd do exactly that.
I thought they went to electronic speedometers in Firebirds starting in 1987? So anything from 1987 on up is an electric and 1982-1986 are mechanical. At least for the Firebirds. The Camaro may be a different story.
I know a guy that has a digital dash for a firebird not sure the year maybe 87. If someone needs one I'll ask him a price and info. Its in pretty good shape
Car: 91 Z-28
Engine: 360TPI
Axle/Gears: 3:73
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
aww they dont sell them anymore i cant find them on their site
Car: 1990 camaro RS
Engine: 1998 ls1. 5.7L
Axle/Gears: 4th gen rear end for got the gears
Car: 92 camaro RS
Engine: Vortec 355,262/268 cam,670holley
Transmission: 5speed
hey all, i am in the process of swapping and truing to figure out if i need to keep the wires running from the ecm to the buffer box
ambainb
Apr 25, 2016 09:21 PM
