head rest removal
Old Nov 26, 2009 | 09:55 PM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
head rest removal
i know this is probably a stupid question.. but i have an 87 iroc and was wondering how you get the head rests to slide up completely out of the seat?? it doesn't look like there is a button to push or anything like that and the things just wont come out. any info would be greatly appreciated.
Old Nov 26, 2009 | 10:28 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: head rest removal
I just did this on my 89 RS as I'm getting ready to re-cover the seats. You need a long, flat, flexible tool to slide down the front side of the headrest bar. This will keep a button from dropping int the hole of the bar, and you can slide it out. I used a hacksaw blade and slid it down in there, took a couple of tries to keep it in the center of the bar, but it did the trick.
Old Nov 27, 2009 | 10:57 AM
thanks a million! i am getting ready to head out to the garage and try this.. i'll let you know how it works out for me!
Old Nov 27, 2009 | 07:05 PM
i straightened out a big hose clamp and slid that down in there. it worked like a charm! thanks again!
Old Dec 28, 2009 | 01:22 AM
gearhead4's Avatar
Car: My Son has a 84 Z28
Engine: 305 4BBL
Axle/Gears: ?
Wow thanks this was kicking my butt. My son will think I am a genius…..well for a minute anyway.
Old Dec 28, 2009 | 11:56 AM
Al Hasse's Avatar
Pretty easy, I watched the upholstery guy I had do my other car remove the headrests from the seats. I thought it was going to be alot harder until I actually took the first one off
Old Dec 30, 2010 | 05:00 PM
torque_is_good's Avatar
I just re-did mine about a month ago. I used a feeler gauge. Slide it dead center of the metal post, in the front. As the headrest is pulled up it will continue to slide upward
the feeler gauge was long enough to do the job
Old Jan 1, 2011 | 01:14 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
https://www.thirdgen.org/forums/inte...headrests.html
Old Jan 27, 2011 | 09:01 AM
dg465's Avatar
I got a starter shim pack from napa. tride the hacksaw blade and couldnt get it centered enough. pretty easy once you figure it out.
Old Jan 27, 2011 | 04:32 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
How about the leaver that that releases the back of the seat to make it fold down,what tool do you use.
Thanks for asking,I didn't know either.
Old Jan 28, 2011 | 06:12 AM
dg465's Avatar
let me check the book later and will get back with you.
Old Feb 3, 2011 | 08:53 AM
dg465's Avatar
okay now i got hte head rest off the seat, how do i finish getting the upholst off? Ive "opened" the bottom by flipping the plastic tab. do i have to rip the seam or what?
Old Feb 3, 2011 | 09:21 AM
do you mean for the headreast? The covering is probably stuck where the seatbelt clip was. The cover will slip off, just pull and tug. Or, break out the utility knife. It's like removing an old exhaust, why undo bolts if you aren't going to re-use it? Break out the sawzall. The same with the headrest cover, use the utility knife if it won't slip off.
Old Jun 15, 2013 | 10:21 AM
pontiacdog's Avatar
Car: '86 Trans Am
I'm trying to do the saw blade trick on my '86 trans am seats but it doesn't seem to work even though it's centered in the middle.
It's a very long blade and it just stops at some point no matter how hard I shove it in there.
Old Jun 15, 2013 | 11:18 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Put the headrest in a full pulled up position.
Side the saw blade into place on the headrest support bar.
Push the headrest and blade down together and that should
trip the release button.
Old Sep 1, 2017 | 06:07 PM
July07's Avatar
This worked perfect for me, Thank you
Frozer!!!
Jan 19, 2024 04:55 PM
camaroken83
Aug 10, 2015 11:35 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
