Firebird radio/hvac pod
Old Aug 23, 2017 | 02:11 PM
rgauder's Avatar
Car: 1987 Trans Am
One of the areas around the mounting bolt has broken on my radio/hvac pod. What kind of glue is best to repair this piece?
Is it abs, or should I use gorilla glue?
Old Aug 23, 2017 | 09:18 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Firebird radio/hvac pod
IIRC, it bares an ABS logo molded into it somewhere.
My was broken in several places. I went through a couple of iterations, and many steps to repair it. I used Gorilla Glue for the vinyl, JB Weld with mesh reinforcement, and even metal straps and screws. But thus far, it's holding up nicely.
Repairs start at post 151 here.
https://www.thirdgen.org/forums/memb...ml#post5903431
Old Aug 24, 2017 | 07:24 AM
rgauder's Avatar
Car: 1987 Trans Am
If it's abs, I could use abs cement then.
Old Aug 29, 2017 | 09:50 AM
rgauder's Avatar
Car: 1987 Trans Am
It was stamped ABS on the back, so I used some ABS cement. Seems like a strong bond, just like abs plumbing pipe.
Old Aug 29, 2017 | 12:00 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Acetone for abs.
Old Aug 29, 2017 | 12:18 PM
rgauder's Avatar
Car: 1987 Trans Am
Main ingredients for ABS Cement are: MEK, ABS resins and Acetone.
Old Aug 29, 2017 | 01:05 PM
Engine: LB9
Axle/Gears: 3.08
And acetone itself welds abs. So if you don't want to add material: acetone.
Old Aug 31, 2017 | 02:09 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Thats good to know!
Old Aug 31, 2017 | 02:20 PM
DynoDave43's Avatar
Yeah, wish I'd have tried that with mine. If I ever have to re-do another one, I'll keep this in mind.
My center console is coming out this winter for a refresh. We'll see what it may need.
Old Aug 31, 2017 | 02:55 PM
rgauder's Avatar
Car: 1987 Trans Am
Ya, but the wife didn't want to share her nail polish remover, so I used the abs cement.
Old Aug 31, 2017 | 03:01 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Thats funny! My wife ask's me to go out in the garage and fill HERS with MINE!!
That didn't come out right....
She wanted some of MY acetone, not MY polish remover!!
Old Sep 2, 2017 | 09:54 PM
1992 Trans Am's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
You could just get a replacement one...I'm sure someone on here has one they'd part with for cheap.
