Coil Spring
Old Dec 8, 2009 | 01:09 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Coil Spring
I've ran into some trouble removing the coil spring from my car. I need to replace it, but I have came to find out that the little plastic piece that's built into the steering column that you press the plastic horn button tube and twist into is broken. I need to replace this. Any ideas how to disassemble it?
Old Dec 8, 2009 | 07:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Coil Spring
I used a Dremel and a rat tale file to re-notch the plastic piece so that the spring, which has a small plastic ear that fits into the notch, stays in place.
JamesC
Old Aug 15, 2010 | 01:15 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Coil Spring
Wrong spring.
Old Aug 18, 2010 | 10:13 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Re: Coil Spring
The spring in the steering column, not the ones on a-arms lol
87v6Bird
Jul 1, 2018 04:12 PM
timonator
Sep 17, 2015 06:57 PM
sandman92084
Sep 12, 2015 10:27 PM
Jlanz55
Sep 6, 2015 03:05 PM
