parked for winter(should I worry about mice?)
Old Dec 15, 2009 | 09:16 PM
Njs305t/a's Avatar
Car: 1987 Trans Am
Axle/Gears: 2.73 posi
Should I worry about mice? I live on Long Island NY in a suburban area. If mice are a possibility what is a good way to keep them out of my car? I don't want to use moth ***** because they smell terrible. And since i wont be messin with my car until spring the odor will be really strong when i do open the car. I hear dryer sheets work. My interior is practically mint so i do not want mice to ruin it.
Thanks,
Nick
Old Dec 15, 2009 | 09:29 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: parked for winter(should I worry about mice?)
yea i would do something under the hood and inside, i have seen the dryer sheets idea in some of my motorhome magizines, i dont know how many to use and how long they last. but i would fill my inside with them and use nasty moth ***** under the hood
i know there is other ways to rid mice but cant remember them, there is also a comercial product that will not smell like moth ***** at your better rv dealerships or stores
BTY my friends work truck got rats that ate some of the wires under the hood between friday night and monday morning this week
Old Dec 16, 2009 | 09:46 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Forget all the old wives tales. moth ***** are for moths.
Get some of the d-con poison pellets. put one under the hood, and one in the passenger compartment. They are very effective. Its apoison that makes them bleed out internally. It also makes them very thristy, so they crawl out looking for water, not die in the walls where they will stink. They are really the only solution if you arent going to periodicaly open the car and check it. If are goign to check it sometimes, use some mechanical traps too, but obviously those will stink if you dont empty them. If theres a good hunting cat nearby, make sure it knows the car is there (sit in it with the cat for a bit), and a good mousing cat will stake out the car and guard it all winter.
While im sure you're mouse problems arent as bad as ours here in VT, they are everywhere, and its amazing how mauch damage they can do.
Old Dec 16, 2009 | 10:09 AM
da.slyboy's Avatar
Car: 84 frankenstein Z28
I second the mouse pellets. I have a 67 truck that I have left sitting for months (sometimes years) at a time. I put one package under the vehicle and one in the car on something that is easy to clean (like a floor mat). Every few months I would come back to check and find the packets empty, but no evidence or smells of mice anywhere. If you check it more often then I do, a good live trap close to the vehicle works well too
RedLeader289
May 28, 2019 01:47 PM
tmellott89
Oct 14, 2015 02:06 PM
meeklay812
Oct 1, 2015 03:46 PM
lewandom
Oct 1, 2015 08:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
