4th gen center consule
Old Dec 21, 2009 | 07:53 PM
Rodimus_Prime's Avatar
Car: 1989 Turbo Trans AM #82
Engine: 3.8 Turbo V6
Transmission: 2004R
Axle/Gears: 3.27 9 Bolt Borg Warner Rear
Im sort of a newb with this car I recently found out that a 4th gen center consule can be swapped into a 3rd gen GTA
is there a how to on this or anyone have pics of this, that would help also. Mainly im wondering if the power window switches are in the center or if they wire up the same?
Old Dec 22, 2009 | 09:23 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 4th gen center consule
There are quite a few posts on this very topic, but I posted up a few pics of my install here: https://www.thirdgen.org/forums/inte...d-console.html
Old Dec 22, 2009 | 11:05 PM
Transmission: 2004R
are the power window switches in the middle for the 4th gen also?
And how do you wire them up im assumming the switch is different on them as well if they are on there
Old Dec 23, 2009 | 12:25 AM
sablemaniac's Avatar
Car: 1982 Trans Am
Engine: LG4
no i believe they're in the door panels.
Old Dec 23, 2009 | 01:17 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
no. you would have to cut your own holes. There are 2 main options for the center consoles. The LT1 style (93 to 97 I think) and LS1 style (98 to 02 I think) and you also have to decide if you want a manual or automatic shifter plate. But on all of them you have to fabricate your own hole. Its not hard if you have a dremel which you can get from walmart for about $20. The manual shift plate console will fit and drop in easier than the automatic. The automatic center console will require more work to get it to work properly...
Old Dec 24, 2009 | 09:05 AM
Transmission: 2004R
ah crap i thought it would be a bit easier
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
