broken heater blend door arm...
Old Jan 2, 2010 | 12:08 AM
classof87z's Avatar
Car: 1987 IROC Z bone stock
Engine: L98 TPI
Transmission: stock
Axle/Gears: stock
Any suggestions where to get parts to repair a broken heater blend door.. I was taking the control cable off and broke the pot metal arm off that the cable attaches to. The door is really stiff when trying to move by hand... Is it a real pain to pull the blend door out??
Old Jan 2, 2010 | 01:58 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: broken heater blend door arm...
I fixed a similar problem a while back. You might be getting parts from the junkyard, I got what I needed from someone parting another car.
I had to pull the dash away from the firewall to do what I needed to do.
https://www.thirdgen.org/forums/cool...ox-repair.html
Nevermind all the wiring in the pictures, I have a bit more electronics than most
Another thread from my local board
http://cascadecrew.org/phpBB2/viewto...?p=60571#60571
Old Sep 7, 2011 | 11:39 PM
banksGTA's Avatar
Car: 87 GTA
Axle/Gears: 3.42 posi
My pot metal piece also shattered in a thousand pieces, how did you fix yours?
Old Sep 8, 2011 | 10:01 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
It may sound impossible, but I was able to pry one off of a spare heater box. If you look at it closely you'll see a D shaped hole where it slips over the door shaft.
Do this at your own risk though, because the spare lever could very well break when you pull it off. The broken piece on my car pulled right off, but the piece on the spare box took about 30 minutes of gentle pulling with pliers before it decided to come loose. I knew pulling the heater box was beyond my skill level.
Old Sep 9, 2012 | 09:23 PM
Kelsroc's Avatar
Car: 1987 IROC
Old thread I found, Any new answers? Any reproduction arms? Any NOS stuff around? Any GM part Numbers for this?
I got my arm off it was pretty easy but had to pull one side of the dash out to get the cover off..Anyone have a parts car that has one?
Old Sep 11, 2012 | 11:09 AM
Kelsroc's Avatar
Car: 1987 IROC
Well couldnt find one so I had one of my Buddys Make one...Works for me
Attached Thumbnails broken heater blend door arm...-camaro-heater-linkage-001.jpg   broken heater blend door arm...-camaro-heater-linkage-002.jpg   broken heater blend door arm...-camaro-heater-linkage-003.jpg
Old Sep 12, 2012 | 11:05 PM
banksGTA's Avatar
Car: 87 GTA
That is a nice piece anyway he could make a couple more? Those are hard to find, mines still not fixed.
Old Sep 13, 2012 | 04:11 PM
87350IROC's Avatar
Car: 87' IROC
OOOhhh. I want one of those. Care to make another?
Jon
Old Oct 10, 2012 | 09:02 AM
Gentry1's Avatar
And I want one too!
Old Oct 10, 2012 | 09:27 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
That scares me to death. And its in my future!
Old Oct 14, 2012 | 09:41 PM
Slick71ss's Avatar
Car: 87 Iroc
Axle/Gears: 3:27
Could someone post a photo of how the cable hooks up to the little blend door lever pictured above? I need to fabricate one of these and am wondering if I'm missing a part that goes on the end of the cable.
Old Nov 1, 2012 | 01:17 PM
banksGTA's Avatar
Car: 87 GTA
Are their any replacements made for these?
Old Jul 13, 2014 | 11:45 AM
Tommysbird's Avatar
Is your friend willing to sell me one?? I have had no luck finding one at all....
Old Oct 13, 2014 | 02:44 PM
ndz's Avatar
ndz
Car: 1987 Camaro Iroc / 1970 Camaro Z28
If you cant sell any or make more, did you have dimensions available so we can make our own? Id like one too! mines in 20 pieces!
Old Oct 13, 2014 | 02:52 PM
ndz's Avatar
ndz
What is the bore, key/flat spot size, and overall part dimensions? Does anyone have them? I can get some made in my machine shop if I had an original in good shape to measure!
Old Jan 25, 2015 | 02:53 PM
BM2's Avatar
BM2
Car: 1987 IROC
Engine: 5.7L
Hey guys-
I know this is an old thread, but does anyone know of someone making replacement linkage arms? I broke mine trying to free up the blend flap. I really don't want to take my dash out just for this. Thanks,
Old Sep 2, 2017 | 04:07 PM
HB Z28's Avatar
Hate to revive an older thread but has anyone found a good solution to this problem? I'm putting my car back on the road in Spring and the heater door is one problem I have to tackle as my pot metal arm is also broken.
Thanks.
Old Sep 3, 2017 | 11:53 AM
BM2's Avatar
BM2
Car: 1987 IROC
Engine: 5.7L
I ended up buying a used heater box assembly that had an intact flap arm. Was able to remove the intact arm and my broken one with very careful prying and lots of WD40. Good luck.
Old May 11, 2022 | 10:10 PM
nickalope24's Avatar
Hey guys, I know this is an old thread, but if any of you are still searching for a lever, feel free to reach out. I just had my cousin machine a brand new temp door lever for my 87 trans am. It has a set screw you tighten down to grab the flat side of the D shaft. Works perfectly. I have 2 extras currently and he can make more upon requests.
Old May 16, 2022 | 11:32 AM
87350IROC's Avatar
Car: 87' IROC
Hi there,
I would love to buy one. I see your private messages are disabled. Can you shoot me a message at john_perdoch(at)yahoo.com ?
Thanks,
John
Old Jun 6, 2022 | 10:09 AM
sdc5555's Avatar
Car: 1987 IROC Z
Transmission: 5 spd manual
Axle/Gears: Borg Warner 3.42 G92 Option
Nick,
I'll buy one of those metal climate control arms for my 87 Iroc, email me price at sdc5555@aol.com.
Thanks, Shane
Old Nov 3, 2022 | 11:01 PM
Hey guys, I know this is an old thread, but if any of you are still searching for a lever, feel free to reach out. I just had my cousin machine a brand new temp door lever for my 87 trans am. It has a set screw you tighten down to grab the flat side of the D shaft. Works perfectly. I have 5 extras currently and he can make more upon requests.
Still have several temp door lever for anyone in need!
Old Nov 9, 2022 | 09:34 PM
dscotch's Avatar
nickalope24, how much for one?
Old Nov 9, 2022 | 10:03 PM
Price update: $60 for the lever plus $10 shipping. $70 total
Old Nov 16, 2022 | 04:41 PM
Mike87TA's Avatar
Car: 1987 Trans am
Engine: 5.0 TPI
$40 for the lever plus $10 shipping. $50 total
Can shoot me at email at mbryceland22@gmail.com? I desperately need you buy one of these. Thanks.
Old Nov 16, 2022 | 04:46 PM
Mike87TA's Avatar
Car: 1987 Trans am
Engine: 5.0 TPI
Old Nov 18, 2022 | 07:33 PM
Mike87TA's Avatar
Car: 1987 Trans am
Engine: 5.0 TPI
Old Nov 18, 2022 | 07:40 PM
Mike87TA's Avatar
Car: 1987 Trans am
Engine: 5.0 TPI
Old Nov 26, 2022 | 02:58 PM
Yellowlt1's Avatar
I'd be interested in buying one if they are still available!
Got this project going.
Old Nov 27, 2022 | 04:07 PM
(Duplicate)
Old Nov 27, 2022 | 04:13 PM
Originally Posted by Mike87TA
Mike sorry for the delayed response, I did just send you an email. Yellowlt1, sweet project man and I do still have them available. Anybody who's serious can send me an email at heslopnick@yahoo.com.
Old Nov 27, 2022 | 04:17 PM
(Duplicate)
Old Nov 27, 2022 | 04:18 PM
(Duplicate)
Old Nov 27, 2022 | 04:21 PM
I can crank out as many as needed (sorry for the duplicate posts!)
Old Dec 1, 2022 | 12:32 PM
Hello, sorry for the delay, they are still available. Anybody serious can send me an email at heslopnick@yahoo.com!
Old Mar 15, 2023 | 11:07 AM
ermandadana's Avatar
Old Jan 7, 2026 | 03:14 PM
Hey guys, between the forum and my listing on ebay, I have sold a couple dozen lever kits now. One of my most recent sales has me gun shy though. His car blend door was cable driven (I think the majority are). He ended up having to make a plate to bolt to my lever, so he could have a 2 peg lever vs the one peg lever I sell. Long story short he got it to work and all is well. However, I'm wondering if he was the only one that needed to do that, or if there are others out there that have bought my lever and not had good luck? If my lever only works on certain trim packages, I'm debating on shutting it down. I am trying to provide a solution here and not another headache lol.
Any and all feedback is welcome, especially from those who have purchased.
Thank you.
Streetrod4
Exterior Parts Wanted
Oct 15, 2018 08:47 PM
V8SC1987
Jul 26, 2017 07:55 PM
Maverick H1L
Jul 3, 2007 07:01 PM
blackchr
Jul 15, 2006 07:52 AM
Eric 97 Z28
Mar 17, 2004 06:47 PM
