Anyone installed a grab handle?
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
Just curious if anyone installed a Oh **** handle in there camaro. I'm thinking about putting one in when i do the headliner here soon.
I'm, assuming it would be okay to install it with sheet metal screws that are short and just enough to go into the lower ceiling metal right?
-Scott
-Scott
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Anyone installed a grab handle?
T-Tops in mine exclude any Oh **** handle. So for my car ...
If you're a guy - grow a pair!
If you're a girl, you'll just have to grin and bare it (ALL)!
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
You could just use short sheet metal screws, but they are not going to hold very much. So if anyone actually pulls on it with any kind of force, it could very well pull out in their hand. Unless you put some kind of backing plate to reinforce it a bit...like having a washer behind the metal or square metal piece to allow more surface area. I would probably use a larger screw/bolt and have it tapped or use a nutsert some sort in the metal if possible. Otherwise it would be mostly for decoration in my opinion.
Engine: 355 chev
well i've never tried t install anything up there so thats why i asked.. How are the stock ones installed on cars? i'll do what i have to to get one in there....
BurlyChev
Aug 22, 2015 01:52 PM
