which leds
Old Jan 19, 2010 | 09:33 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
which leds
hey i have a 88 trans am and i wanted to know if someone could give me a link to red led gauges that will go into my dash.... which ones do i need for them to light up evenly.... thanks in advance.
Old Jan 20, 2010 | 07:37 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: which leds
You might investigate the following link (I purchased from them when I went to LED's in my overhead console.):
http://www.superbrightleds.com/
JamesC
Old Jan 20, 2010 | 11:22 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: which leds
If you go superbrights you'll need to get bulbs with at least 4 leds in them, preferably with 6. My Firebird actually has bulb cover on the incandescent lights and it's plenty bright and even.
Alex
Old Jan 20, 2010 | 11:31 PM
88fastgta's Avatar
Re: which leds
thanks... i have another question.... if i get blue leds... what color would my needles light up... cause they are painted orange....
Old Jan 21, 2010 | 12:05 AM
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
Re: which leds
hmm its hard to say what color they will shine. Did they shine with just regular incandescent bulbs? I did this to my Z not to bad they are with 5mm ebay leds I'm pretty happy with the results. My suggestion is I would get the leds separate that way I can put them where ever I wanted to get the best results. From what i heard try putting foil tape like aluminum tape something shiny between the clear lens and the face plate with the shiny side facing the gauges to try and reflect the light back on the faces of the gauges. I'm gonna try starting the after I get done building my girl back up.
camaro_mann's Avatar
Car: 1986 Iroc-Z28
Transmission: 4L60
Axle/Gears: 373
Re: which leds
this is where i got my led lights plus the white face stickers..
http://www.whitegauges.net/
Old Jan 21, 2010 | 07:05 AM
88fastgta's Avatar
Re: which leds
i remeber when i had clear bulbs the needles shined orange at night..... it also shined orange with the orange bulb covers but only the needles.... the rest of the gauge was clear/white looking..
Old Jan 21, 2010 | 07:59 AM
blackroc68's Avatar
Re: which leds
They will light up blue!
Old Jan 21, 2010 | 11:20 AM
z28 TPI's Avatar
Re: which leds
They might light blue...if the brighnest of the surrounding leds is brighter than the needle. Otherwise the needles will glow color that doesn't look to good ever mix orange and blue together its a brown of some sort. I know of mods that make that surrounding light blue but right underneath the gauge needles they put white leds to make the orange needles glow orange. They also paint the whole surrounding area of the cluster black on the inside to help trap the light. I wouldn't recomend on the camaro nor the trans-am clusters though. Another thing you might want to do 88fastgta is to sand off the back side of the gauges to allow the led light though whatever color you are planning. If you were close to me I would tell you to send me your cluster and I would do the work for you, but you're not sorry. I hope this helps you.
Old Jan 21, 2010 | 12:12 PM
88fastgta's Avatar
Re: which leds
z28 tpi.. i dont have the stock black gauges i have white overlays on my gauges now..... would that help any.. here what my gauges look like now
http://www.whitegauges.net/products/...ce-Gauges.html
also im getting nine of the blue bulbs
http://www.whitegauges.net/products/...ment-bulb.html
these should be alot brighter than the stock bulbs... i hope it lights up blue.....
Old Jan 21, 2010 | 09:57 PM
z28 TPI's Avatar
Re: which leds
Yeah should be cool for what you want to go for. I would still put foil tape on just to reflect the blue light back to the gauges. Looks good.
Old Jan 21, 2010 | 10:07 PM
88fastgta's Avatar
Re: which leds
where do i put the foil tape at...
Old Jan 21, 2010 | 11:16 PM
Re: which leds
Don't know if this will help much but. On an older post about this I remember someone saying that they removed the needles and sanded off the old orange paint and then painted them the back light color (think it was green in their case). I think it'll just depend on how bright your LED's are. As far as foil the only place I could think of would be the back of the cluster "bucket," unlike Camaros, Firebirds have transparent gauge markings instead of being lit from around the gauges. Therefore, I don't think that the foil tape will help all that much.
Old Jan 25, 2010 | 04:22 AM
z28 TPI's Avatar
Re: which leds
Yup sorry. Novafirebirdguy is right I for some reason or another thought you had a camaro i see now that you have a GTA duh me. Anyways the foil tape you could put on the back of the cluster (the white plastic) to reflect the light whatever might be given off back to the gauges themselves. This will make it a bit brighter for you. Again forgive my ignorance sorry I didn't see your GTA.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
