shift knob removal
Old Jan 23, 2010 | 07:56 PM
aks's Avatar
aks
Car: 92 Z28
shift **** removal
Hi everyone, I have a 92 z28 automatic 700r4 with the leather wrapped shifter. I have searched these forums on removal of the shift ****. All of them say there is a small clip on the back side (radio side) of the shifter.
However, mine does not have this clip. I have pulled off the center shift release button and do not see a clip down there either. So i have no clue how to get the shift **** off.
I'd like to remove it without destroying it, but I guess I'll do whatever it takes.
Does anyone have any idea of how I can remove it?
Old Jan 23, 2010 | 08:23 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: shift **** removal
These links may help.
>Link
>Link
Or post up a pic so we can see what you have.
Old Jan 23, 2010 | 08:31 PM
aks's Avatar
aks
Car: 92 Z28
This is the best picture I have of it right now. Maybe its press fitted on?
Old Jan 23, 2010 | 08:44 PM
Scorpner's Avatar
Engine: V6, V8
Agh. I don't remember which one that is. I took mine off right away because it used to jam all the time. It's not press fit though. It's either one of the two. The snap ring may not be easy to see.
Old Jan 24, 2010 | 09:16 AM
aks's Avatar
aks
Car: 92 Z28
Hmm, I still don't see any snap ring down there. Cleaned it out with a rag and que tips to get all the greese out, and still don't see anything. Thanks for the help.
Old Jan 24, 2010 | 09:46 AM
Scorpner's Avatar
Engine: V6, V8
With you foot on the brake try putting the car in first to see if it doesn't have a slit for a U shaped clip in the front. Sorry I wasn't much help.
Old Jan 24, 2010 | 09:58 AM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
If the clip is missen then u should just have to pull it off. Try pushin in the button then pull the **** off
Old Jan 24, 2010 | 10:10 AM
aks's Avatar
aks
Car: 92 Z28
ok I checked the back of it even pulled apart all the stitching on the back and there is no u shaped clip lol. and there is noting underneath the push button wtf.
Old Jan 24, 2010 | 10:59 AM
Scorpner's Avatar
Engine: V6, V8
I went out to the shed...
And found the old square style I had, It was a solid plastic one but it had nothing for a U-shaped clip so I'm pretty sure it used a c-clip under the button. Try wiggling it to see if you can see anything or maybe a small shot of WD-40 in there to wash any dirt out of the c-clip holes.
You're looking for this right?
Someone may have used a different style as well. You should be able to see the top portion of this, from the groove up:
On some of these the center plastic piece pulls out. Don't force it if yours doesn't, but if you can remove it you should be able to see if anything crosses the groove area from a different angle.
Someone could have thrown one of these in there as well:
Old Jan 24, 2010 | 11:25 AM
aks's Avatar
aks
Car: 92 Z28
alright i'll give that a try
thanks again.
Old Jan 24, 2010 | 11:34 AM
aks's Avatar
aks
Car: 92 Z28
no, there is defintley nothing down there.
Old Jan 24, 2010 | 12:24 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
The round ball **** has a snap ring under the button. The **** on later models such as yours are held on with a clip.
Here's two shots showing the location of the clip. It's shaped like a huge, unbent staple. Pry the clip out with a small bladed tool. The **** pulls up and off.
Old Jan 25, 2010 | 06:31 AM
aks's Avatar
aks
Car: 92 Z28
yea but mine defintley doesnt have that clip. i even peeled off the leather. and ive tried pulling it off wont budge
1992 Trans Am
May 10, 2023 07:19 PM
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
dhonda200
Aug 11, 2015 11:50 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
