Dash Shell, What years will interchange?
Old Jan 27, 2010 | 07:47 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
I recently purchased an 89 Iroc and have been going through it fixing things. I was replacing the dash speakers and noticed the dash shell is craked and broken all to hell. It is broken in so many places It would be futile to even attempt to rig it for now. I was wondering what year models will swap directly with no mods.
Thanks.
Old Jan 27, 2010 | 08:37 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Dash Shell, What years will interchange?
at least 85-89, 1990 was the first year for digital dash, and i'm not positive on 82-84 dashes. Should be good to grab a shell from any model as well, as they all have the same hole setup for the badge on the passenger side.
Old Jan 27, 2010 | 09:19 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
82 - 89 Dash Shells are the same. There are 2 types,... With and without Air conditioning.
When it comes to the wiring harness - only an 89 will be plug/play. The 89 used VATS and cable speedo,... 89 was the only year that happened so other years will need modification to work correctly. ( Meaning - just pull your harness off the original shell and re-use it ! )
Old Jan 30, 2010 | 05:43 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
must be a camaro thing only that 82 is same as 89 but in firebirds it not...
consoles and all are different
and i know the consoles in 82 are definitely different where they meet the dash, from an 89
so i dont know..
i have all of them laying here and they arent even close to the same shape design.,.
82 83 84 is pretty unique on 75% or more of the interior parts, than 85-up
might as well be a whole other generation from 85-up because they are that much different than later years..
most ppl dont seem to know it..
good luck
Old Jan 30, 2010 | 07:43 PM
Drew's Avatar
Actually the Firebird break down is closer to 82-84, 85-89, then 90-92. Some of the 85-89 parts will interchange with 90-92 but not all. The accessory switches for example are different, along with the panel under the steering column, but the panel on the lower part of the passengers dash and the dash pad are the same.
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
lt1z350
Sep 29, 2015 01:50 PM
Street Lethal
Aug 14, 2015 08:25 PM
