Weather stripping Problem!
Old Jan 28, 2010 | 10:46 AM
89v6firebird's Avatar
Car: 89 firebird (v6) T-top.
Engine: v6 EFI
Transmission: IDK
Axle/Gears: IDK
I have a 89 T top, and when it rains, it leaks inside. The interior is something I hope to tear out in the summer and replace, but in The mean time i need to fix teh weatherstripping, where do I get it? and how do i replace it? Is it glued on? and tips or websites of how to do all of that? thanks!
Old Jan 28, 2010 | 12:06 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Weather stripping Problem!
i bought all mine from www.soffseal.com it is guled on and there are some push pins /a track that holds it in. make sure you dont have any rust holes on the t-top frame like how i did but i got mine fixed.
this is after it was fixed
that is where mine was leaking from and you can see the tracks on top and the right.
you have to open up everything to realy see what you got going on under their
Old Jan 28, 2010 | 12:48 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
I tried the OER t-top kit from Classic Industries and basically threw away money. Next, purchased all new GM weather stripping for my 3rd gen. It fits and seals like it should.
Soffseal makes good products too. Have used their door seals, hood seals, trunk seals, etc. in several of my cars with good results.
Old Jan 28, 2010 | 06:46 PM
JackRs's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
1A Auto is very well priced and fair.
I asked Dan, he's a member on the site the same question in a pm.
He was very helpful and they have the cheapest weatherstripping i've seen.
Heres a quote from the message he sent me.
(Mine was in regard to the door weatherstripping.)
The seals on the doors are pretty easy to change compared to the other seals on these cars. The doors seals are held in place by plastic push pins, so you just pull them out to remove the seal. There are a couple screws toward the tops of the doors that must come out as well, but they're easy to spot.
Installing is just the reverse. Some people like to put a little weatherstrip adhesive on the seal in between the push pins, but its not required. Bear in mind, if the door is sagging at all (and its not uncommon on these cars), it may be a bit hard to close the door when the seals are first installed.
Hope this Helps!
Old Jan 28, 2010 | 06:47 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Transmission: The kind that goes "kachunk" in 1st
Well... I had a good one on a parts car I had... until it was stolen from it. =/
Old Jan 28, 2010 | 10:22 PM
99transamgirl's Avatar
Car: 84, 99 Trans Am
Engine: 305 G, LS1
I'd do Soffseal as well. I had the metro brand t-top seals last year. They were o.k. but didn't look exactly like the original, didn't fit as well, and a pain to get my t-tops to come down and close. We had to adjust the latch as high as it would go and still leaning on top of the tops while the other person tried to latch them. We then left them like that for a long time. We got the car painted this Dec and put new seals on the t-tops again but with Soffseal from Summit racing and it's great. Looks like the original and fits a lot better.
Old Jan 29, 2010 | 09:15 AM
1Aauto's Avatar
Former Sponsor
Nice job fixing that area.That came out great.
Old Jan 30, 2010 | 10:55 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
And now I figure out that the 8-piece kit in the Classic catalog is junk.
Anyways, you were looking for a site, look here: http://www.fierottop.com/waterleak/
It's for Fieros, but the idea is the same throughout GM. I plan on using plenty of autobody seam sealer up there when I redo mine.
Old Jan 30, 2010 | 03:16 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
if that tords me than thanks! lotta work
Old Feb 13, 2010 | 08:43 PM
Engine: v6 EFI
Transmission: IDK
Axle/Gears: IDK
Thanks, what would a repair like this cost me? Theres an upholstry place in town that does this. But Im sure its not difficult, I want to learn how anyway, so if in the future i can do it again.
Old Feb 13, 2010 | 09:03 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
89v6- a repair of just the weather stripping or what I did?
the weather stripping is not hard to do, just put some good beats on and then take your time.
the repair of the weatherstripping rails is alot harder b.c that metal is oddly shaped and is very thin and it can warp very easily
1992 Trans Am
May 10, 2023 07:19 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
LittleFranks
Sep 17, 2015 12:22 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
g.l.mos
Aug 22, 2015 12:02 AM
