Old 4 speed clutch brake pedal assembly
Old Jan 28, 2010 | 03:56 PM
caseworker2's Avatar
im gettin a t5 for my car and have access to a clutch brake pedal assembly from the old 4 speed manual. Im not sure if there is any difference so i can know whether it will work with the t5 and slave cylinder and all. any feedback would be greatly appreciated.
thanks
Old Jan 28, 2010 | 03:59 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Old 4 speed clutch brake pedal assembly
As far as I know, the old style was a mechanical clutch, whereas the newer style was hydraulic. They may not work, but I am not 100% sure.,
Old Jan 29, 2010 | 05:27 PM
i appreciate the help. i found a t5 on cragslist and the guy has everything for it except the pedals. but he has an old 4 speed as well with everything. so i was gonna try and gethis to throw in the pedals with but i need to know for sure if they will work.
Old Jan 30, 2010 | 10:49 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The pedals should work... It's the stuff on the other side of the bulkhead that's different. I haven't taken the set out of the 84 at the yard, so I'm not 100% on this.
1992 Trans Am
May 10, 2023 07:19 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
