pedal's too close?
Old Feb 24, 2010 | 09:13 PM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
pedal's too close?
I know I'm not the only one with really big feet driving a 3rd gen . I wear 14's and my feet get stuck between the gas and brake pedals . So to my question have any of you guy's done anything about it (except drive with one shoe off like I do) like heat and bend the brake pedal or using a pedal out of a different car. Thanks in advance.
Old Feb 25, 2010 | 06:54 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: pedal's too close?
I always thought there was good room in the thirdgens. When my car was auto I had no problem, and now that its manual, its even better. I wear 13s, and will get 13 Wides when available. Ive driven with 14s and never seemed to have an issue.
I wouldnt suggest bending anything. If anything, maybe you could trim some of the brake pedal from the right side, just make sure you affix the rubber pad so it doesnt slide off. I mean, my brake pedal is 1/3 the size of the automatic one, so I dont see the difference if you trim it alittle.
J.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ironbmt
Sep 27, 2015 06:00 AM
