1984 TA seatbelts into a 1982 TA?
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: 1984 TA seatbelts into a 1982 TA?
They will work, you just need to update your sill plates as well.
Yes, you will need new door sills or cut your existing pieces to work. You will also need the seatbelt mounting brackets that mount to the floor. We have them available if you didn't get them with your belts.
