Dash help! w/picture
Old Mar 7, 2010 | 03:41 AM
palomo88ta's Avatar
Car: 88 Trans Am 5.0L TPI
Engine: 305 TPI (LB9)
Transmission: 5 speed manual
Hey folks! My 88 Trans Am has the electronic/digital dash in it and the last while the fuel level gauge and half of the speedo have been really dim. I can see the speedo still probably due to the fact that the numbers are so big but the fuel guage is useless. Is this common or where would you check first. I know i may end up taking the dash apart but is there something i could try first? Thanks.
Forgot to add picture....the affected are is circled in red...
Last edited by palomo88ta; Mar 7, 2010 at 03:47 AM. Reason: forgot to attatch the picture
Old Mar 7, 2010 | 06:11 AM
strc09's Avatar
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
Re: Dash help! w/picture
If you're having problems seeing the displays during the day that means the bulbs are going or are already out and need to be changed. With all of the bulbs working that will help daytime visibility of your digital display.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
