why did the PO do this? aka air fresheners inside the vents
Old Mar 21, 2010 | 04:03 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
i have a 91 b4c and the dumbass PO put 2 hockey puck style air fresheners INSIDE the center vents above the hvac controls and that spiel. Is it possible to get these vents out without breaking them or pulling the whole dash pad? need to replace the pad anyways but these things are annoying. rattle like the snake I tell ya
Old Mar 21, 2010 | 07:18 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: why did the PO do this? aka air fresheners inside the vents
The vents are held in place by two small pin on each side. To remove you need to press the side of vent by the pin and release it from the hole. Just do it gently without using a lot of force with a screwdriver. They will pop out.
chazman
Aug 28, 2018 03:25 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
Todd84Z
Sep 4, 2015 08:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
drathaar907
Aug 6, 2015 04:20 PM
